How much bleeding?
Old Apr 18, 2003 | 02:32 PM
scrambled6910's Avatar
Default How much bleeding?
Installed whole new master cylinder on Scram 400 and bled the lines for a half hour. Prolly pumped out enuff brake fluid to drown a horse. How could there possibly be air in the lines? We are doing it by the book and pumping slowly. There is good braking but it seems like it could be better. Is there anything we could do to just make it lock up a little better?
Old Apr 18, 2003 | 03:04 PM
trailblazer275's Avatar
on my 250 trailblazer there was alot of air in the brake lines cause of that my brakes didn';t work good pumb the foot brakes and bleed the brakes thats what i did. and it worked alot better after that.
Old Apr 18, 2003 | 03:23 PM
NCScrambler's Avatar
Are you bleeding it into brake fluid and watching for bubbles to disappear as you are doing it? Very important because as soon as you quit bleeding, without the oil there, you will suck air straight back into the system.
Old Apr 18, 2003 | 03:38 PM
Yeah we are using a clear tube. We were very very careful not to suck any air back into the lines.
Old Apr 18, 2003 | 11:45 PM
polarisman72's Avatar
I bought one of those cheepy 1 man brake bleeding devises for like 5 bucks and it works miracles, i can bleed all of my brakes in like 10 mins, it works unbelivably well
Old Apr 19, 2003 | 12:35 AM
ScRaMbLeRiZeD's Avatar
Yea this bleeding was done to my scrammy. They are better than right after we installed the master cylinder, but could be a lot better. Should I just keep bleeding the lines?
Old Apr 19, 2003 | 12:38 AM
where can i get one of these?
Old Apr 19, 2003 | 03:57 PM
Anchorman's Avatar
The 1man bleeders are at virtually every auto-parts store... princess auto if u have 1, Canadian Tire 'round here, PartSource, etc... or online .. only $7 here,
http://www.classictube.com/prodview.asp?idno=11108
Old Apr 19, 2003 | 07:35 PM
Crawdad's Avatar
I just ran a hose from the back bleeder (the one that's operated by the hand brake) into a half full bottle of fluid. I just kept pumping the master cylinder down halfway and refilling til I filled the bottle in the back. Never closed the bleeder til the bottle was full. Then when I did close it down the brake handle was rock solid.
Whats the condition of your brake pads, are they all good? Also if your caliper seals are blown it will make your hand brake feel spongy cause the fluid is bypassing the seal in that rear caliper. If you can open the bleeder on the rear brake (for the side thats for the foot brake) and fluid comes out when you squeeze the hand brake you know your rear caliper seals need replaced. Just some O-rings though, no big deal to replace.
oliveiracarlos
Sep 7, 2015 03:39 AM
oliveiracarlos
Sep 6, 2015 01:38 PM
toonces
Aug 25, 2015 06:09 AM
SixSpeed5
8
Aug 2, 2015 05:38 PM
