New Wolverine Pics
Old Apr 27, 2000 | 02:27 AM
boomer's Avatar
Posted some new pics of my 99 Wolverine if anyone is interested. My Douglas .190 and Bear Claws should be on by Fri so check back.
http://briefcase.yahoo.com/kenboomer
Old Apr 27, 2000 | 01:25 PM
jcsact's Avatar
Sharp looking bike. I seen a few thing that I would like to ask you about. I seen that you have the DG skid plates. I was wondering did you drill the hole for the front diff. drain plug or was that already there and if you can and will say how much did the engine mods. run you.
Old Apr 27, 2000 | 10:31 PM
blaster18's Avatar
HE must have drilled the hole cause the only one i got on mine is the oil drain plug and i got full dg skids i dont have a pic of the skids but i do have some pics of the wolverine and some of my other quads at http://www.geocities.com/hillsvillespage/home.html
Old Apr 28, 2000 | 12:03 AM
boomer's Avatar
Yeah..I drilled it with a hole saw. It was sort of a pain to line up as you can see cause its not quite centered but I only need enough room to fit a 1/4 in. drive socket in there, so the smaller the hole, the better. The engine mods were around $400.00 for the parts (cam, piston package from highlifter) I also put in sealed front wheel bearings. Only about $38.99 for the bore, and $50.00 for the portwork from a buddy in CA. I did all the labor myself and saved alot of money
Old Apr 29, 2000 | 02:13 PM
Runnintaco's Avatar
That looks real good boomer.....I like the skids and especially like the handlebars.....how much did they run? Were they hard to install/any problems? Very nice....let us know when you get pics with the new rims....
Old Apr 29, 2000 | 11:40 PM
boomer's Avatar
The skids are a bit on the expensive side. About 150 for the middle, 100 for a-arms and 100 for the rear. I think they are worth it though. Its pretty much bullet proof underneath. They installed pretty easy, but the clamps can be a bit stubborn. I drilled the hole in the front so I wouldnt remove it to change fluid in front differential. As for the bars, they were around 25 bucks. They bolted right on with no problems, and the console fit good too. The wheels will be here this week. will post them as soon as I get them on so check back.
Old Apr 30, 2000 | 01:04 PM
Runnintaco's Avatar
Yeah looks real good....are those Renthal bars or another brand? did you get the pad at a Yamaha dealer?
Old Apr 30, 2000 | 07:27 PM
boomer's Avatar
The bars are also DG. I got the Hi-Bend so the console would fit. Pad was from Dennis Kirk.
Old May 1, 2000 | 08:11 AM
musclford's Avatar
Nice Bike!!!!
Toys are expensive, but Fun!!
Old May 2, 2000 | 05:12 PM
blaster18's Avatar
i just took another look at my wolverine http://www.geocities.com/hillsvillespage/home.html
IT does already have the hole up front i was thinkin it didnt but it does. and they are DG Baja skids are u sure yours are dg baja.
