tripped belt failure switch
Old Apr 21, 2003 | 07:19 PM
Scotia650's Avatar
Default tripped belt failure switch
Well this was a first for me. One minute your cruising along at 60 mph, the next your at 5. Beautiful day Friday, big crowd and no power. LOL Nothing is more humbling than to have to crawl past 50 other machines to find a spot to check things out. Wait, is that a 5 year old with pigtails out on her trike, better pull over before she mows me down, nice.
Anyway, better get to the point. After much trial and error, we discovered that we could unplug the second relay from the front (switch circuit relay) next to the shift lever and bypass the failure switch. This kills the dash so you can't tell how much fuel, speed, nothing but it will get you going until you can pull the clutch cover and reset the switch. I checked the forum and didn't see a post on this so I though somebody might find it handy in case your in the same situation. You can unplug the sensor by reaching under the plastic next to the shifter, unhooking the relay from it's mount so it drops down and then unplugging it. I taped up the plug to protect it from the elements and enjoyed the rest of the day. One word of warning though, this switch usually trips because of a belt going south or in extreme need of adjustment so I would consider taking it a little easier than normal on the rest of your ride. I've since replaced the belt and everything is now back to normal.
Anyone else experience this problem or have any comments?
Old Apr 21, 2003 | 07:53 PM
Nightryder888's Avatar
i have heard that the switch will trip itself at some many miles/hours to signal a belt check or something anybody know of any truth in that?
Old Apr 21, 2003 | 09:09 PM
Disme's Avatar
Nightryder888 what you say is not true. The only way the belt condition switch can be turned off is by the belt hitting it and turning it off.
Old Apr 21, 2003 | 11:18 PM
Vforcer's Avatar
this might help
NYRocs belt switch tip
Old Apr 29, 2003 | 02:32 AM
kendawg's Avatar
a completely dead battery will trip this also. or disconnecting battery. and it trips at 100 hours on the '03
hueby
1) Engine problems..
Aug 29, 2015 08:34 AM
hueby
Aug 28, 2015 07:26 PM
toonces
Jul 31, 2015 09:27 AM
Mikesohio
Jul 26, 2015 10:51 AM
trouttracker
Jul 20, 2015 11:54 AM
