Cracked cyl - 295 kit?
Old Apr 27, 2000 | 06:43 PM
SandDraggin's Avatar
I just sent my 250R cyl out approx 2 weeks ago to have a new piston put in it, and the company called me back and said my cyl bore has a crack in it. approx near the intake port. They told me that my cyl was now junk. I was told I could resleeve it but I could run into problems with over heating. I just talked to some one else the other day, a local guy and he said I could resleeve my cyl but I would have to use a special sleeve that is approx. 3 times thicker than the stock sleeve. He also suggested that since I have to use the thicker sleeve that I could go for the 295 big bore kit since it use the same exact sleeve for just a few dollars more. I really liked the idea of the 295 kit, but I need to know HOW RELIABLE is this kit? I have heard some things about the 295 kit having head gasket problems. Is this a good kit and is a fast kit when done? I will mostly just drag the 4 trax and not trail ride that much. The 295 kit will cost me approx. 350 - 400 dollars. Let me here what you think.
Old Apr 27, 2000 | 07:31 PM
sanoduner's Avatar
The problem with the 295 kit is that uses a cylinder that was designed to run 250cc. Larger diameter sleeves lose reliability when then are bored thin, this causes the tendency to crack. If the cylinder is bored to accept a larger sleeve, then its cooling capacity will probably be diminushed.
I nearly turned my 250R into a 295, but I was told that I would encounter similar problems. Although I am not an expert, I would suggest looking into the either the Pro-X 310 jug, which can be reliably set-up to 330cc, or possibly the new PSI jug. I have not tried it but supposedly it can go well over the cc size of the Pro-X jug and it features an exhaust valve. Check it out, it certainly looks trick: www.psiperformance.com. Hope this helps.
-Mike
Old Apr 27, 2000 | 10:38 PM
retro's Avatar
Go to www.macdizzy.com
Read some of the treads or E-mail him. He know a ton about 2 strokes!
Old Apr 28, 2000 | 12:32 AM
Backcountry's Avatar
They're tough to get to make serious power that they are capable of, the bore grows cubically while the port area grows slower. I haven't had any problems with overheating or a lack of reliability. If anyone were to have problems, I think I would have, with the mountains of compression that I have and massive port modifications(read less piston wear area). I run a O-ringed head and have never to date had problems with leaks. Would I have gone with a 330 or 350....yeah maybe simply because the port design and layout of the Pro-X cylinders are better, but we were looking for the challenge of how far a stock cylinder could be pushed...well...the steady diet of twin's proves we did something right....
Old May 2, 2000 | 12:51 AM
xcBanshee's Avatar
i just purchased ct310 cly kit. i race harescrambles and use a paul turner type6 pipe, 38pj carb,12/39gearing, stock reed cage and pump gas w/bel-ray mc-1 mixed 50:1. i raced this combo sunday and was very happy with my combo it's very smooth from top to bottom with a slight mid range hit. after the race i drag raced a 330 i rode the 330 and the other guy rode my bike, 330 pulled a little harder on top but i think that was due to gearing. his bike has paul turner hand formed race pipe, 38pwk airstriker, stock reed cage,13/39 gearing and pump gas. he liked how smooth my bike was. i considered both a resleeve and the pro-cross 310 and choose the pro-cross w/removable combustion camber, because i could get it for $970.00 to my door in 2 weeks. including all gaskets, porting, and jetting. the resleeve jobs range from $500.00+gaskets and jets to $900.00 complete. so i figured why not get a whole new top end and still have a good 250 cly and head as a spare. by the way the guy with the 330 who rode my bike is the current points leader in the missouri state harescramble series, 2-stroke open-B.
Old May 3, 2000 | 10:33 PM
Raychalp's Avatar
Well, first of all, the CT310 cylinders are actually 295 cylinders because without machining the cases you can't get more than 303. The max a 310 cylinder can be bored to is 303. I wouldn't recommend the 295 sleeve because they have problems with overheating. The reason people have problems with the head gaskets is that they aren't using big bore gaskets. The PRO-X cylinders have better porting, better cooling and they come complete with everything you need to bolt it right in. You would be better off with the complete aftermarket cylinder kit.
franklyme
Oct 21, 2016 07:18 PM
Troylee216
Sport Quads
Sep 28, 2015 09:34 AM
greg86hd
Sep 16, 2015 12:32 AM
Jason Campbell
Sep 7, 2015 02:25 PM
