2004 ds650 question.
Old Apr 23, 2003 | 11:59 AM
Jonsride's Avatar
Default 2004 ds650 question.
Does anyone know if the new DS has reverse? and how much are they are going to ask. Just curious.
Old Apr 23, 2003 | 12:48 PM
DSDuneCrazy's Avatar
Nope, no reverse.
The engine is the same as the 2003 models.
I don't really wan't them to add a reverse. It's just more weight added that I would never use.
-Tom
Old Apr 23, 2003 | 03:12 PM
RoostItUp's Avatar
Reverse on a quad weighs less than 5 pounds to add.
Old Apr 23, 2003 | 05:19 PM
SANDMAN430's Avatar
not the way bomb builds things that would be a easy 30 pounds, look the thing over next time i see you everything on the bomb is heavy duty, no breaks that way.
Old Apr 23, 2003 | 05:54 PM
pleasure4qt's Avatar
Dry weight on a 2003 is 490lbs -516lbs wet, which is the dry weight of a 700 V-Force.
2004 the target weight is to be 430lbs dry.
Biggest change is a 1/2 shorter swingarm made of aluminum which changes the weight bias front to rear and should make the front end lighter under hard acceleration and break the rear end loose for slides. Lofting the front end of obsticals should be much easier.
Lighter headlight cowl, and more aluminum.
Rev limiter has been increased also from 7500 to 7800. Maybe new jetting and shocks also.
No reverse.
Old Apr 23, 2003 | 07:47 PM
lilnotts's Avatar
i'd love to have reverse, then i wouldn't be so picky about the weight, the only time i really care about the weight is wen i have to push it backwards or wen i get stuck, i could get unstuck alot easier wit reverse
bigred20653
Oct 2, 2015 10:05 AM
2many2ride
Sep 27, 2015 04:35 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Bernhard
Sep 25, 2015 12:45 PM
Sw00p
Sep 24, 2015 02:50 PM
