Locking differential...Please explain.
Old Apr 23, 2003 | 12:51 PM
MPMAN21's Avatar
Default Locking differential...Please explain.
Hello. I am trying to decide between the Kodiak 400 4x4 and the 450 4x4. The 450 has the locking differential, but the 400 does not. Please explain to me how the locking differential works and how a 4x4 with one works different then one without.
Thank you so much! [img]i/expressions/face-icon-small-wink.gif[/img]
Old Apr 23, 2003 | 01:03 PM
Raffica's Avatar
Well, the 400 has no low range, and the locker means when locked all 4 wheels spin instead of three when unlocked it only spins three for easy turning... The 400 will only have the 3 wheel drive instead of all 4. The 450 you can choose. Aftermarket lockers are available for the 400.
Hope this helps.
Old Apr 23, 2003 | 01:13 PM
MPMAN21's Avatar
Yes, it does. Thank you very much for taking the time to explain!
Old Apr 24, 2003 | 01:02 PM
MPMAN21's Avatar
So, is this "3 wheel drive" worth the $700 over the regular 2wd? Or will it not make enough difference to even mess with it?
Thanks for your help.
Old Apr 24, 2003 | 01:08 PM
BigBearFX's Avatar
yes it is worth the xtra 700. it is "3 wheel drive" when one wheel is in the air and 1 on the ground, the one in the air tends to spin while the 1 on the ground gets little or any power. the locking diff eliminates that and all wheels spin no matter what. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Apr 25, 2003 | 11:29 AM
MPMAN21's Avatar
Thank you so much for your replys. This will be my first ATV, so I am trying to make sure that I get what I want, but not more then I need.
Thanks again! -- Anyone else have comments?
Old Apr 25, 2003 | 11:59 AM
Raffica's Avatar
yeah, keep us posted on your purchase and how you like your quad... Or, buy two and give one to me![img]i/expressions/face-icon-small-happy.gif[/img]
Old Apr 28, 2003 | 08:58 PM
Jarod's Avatar
locking diff. provides "true" 4 wheel drive, with just a limited slip well its a limited slip, not a 3 wheel drive, it will slip for a while but then it will stop usually (unlike a regular diff)
Old Apr 28, 2003 | 09:00 PM
BigBearFX's Avatar
actually true 4x4 is found on most polarisis jarod, the sense what wheel needs traction the most
Old Apr 29, 2003 | 11:05 AM
MPMAN21's Avatar
Thanks again for your posts. This information has helped me alot!!!
