Paddle Configuration?
Old Apr 24, 2003 | 05:15 PM
palebock's Avatar
Default Paddle Configuration?
Ok, quite a few questions here:
In the equation is the 1st number the Height, 2nd width, 3rd Rim Diameter?
With the 22x11x10 Extremes, would you need to go up a couple teeth in the rear?
Anyone have a comment on these setups?
I am trying to decide between the:
22x11x10 Extreme 9 paddle
20x10x10 Extreme 8 paddle
21x12x8 Extreme ?
22x11x8 Edge ?
Thanks in advance
Old Apr 24, 2003 | 06:15 PM
Dfitz's Avatar
Yes and Good luck. As it turns out alot of paddle runners like what they have and they run all you have in your list. Gearing is the same problem. I have asked the same questions and you will have so many different options if you are look for any consistency, not going to happen. Depends on you, your raptor mods and what kind of ridding you like to do.
Old Apr 24, 2003 | 07:44 PM
palebock's Avatar
Thanks for the update. I was figuring that might be the case, but throwing it out there anyway [img]i/expressions/face-icon-small-smile.gif[/img]
If a little about my ride might help in decision, or even make my list larger [img]i/expressions/face-icon-small-smile.gif[/img] here we go.
01 Rappy: +3+1 A-Arms, Custom Axis shocks, Ext. TEAM Axles and Hubs, PEP Damper, Big Gun System.
Ridding: Pismo Sand, 50% Jumping, 30% Hill Climb, 20% Recreational.
Rider: 225#, Moderately Aggressive, but getting more.
Old Apr 25, 2003 | 12:14 PM
Dfitz's Avatar
Here is what I'm doing. I'm going to get the 21" extremes 8 paddle and as for the gearing I purchased cheap steel gears to try different combos. Then when I find the gearing that I like, I will purchase a good set of gears. I'm going with the 21" because it is in the middle of what they all use and it seemed 20" to small, but 22" just to big. I guess I'll find out. Alot of them recomended 8 paddle. Good luck with what ever you do.
Old Apr 25, 2003 | 12:39 PM
palebock's Avatar
Thanks Dfitz
Old Apr 25, 2003 | 03:04 PM
BlueLeader's Avatar
Sand Skate II V paddels 13/42 gears. works for me.
hugemoth
Jul 20, 2020 03:28 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
Aug 25, 2015 11:16 PM
