WHEN MY TAIL PIPE HITS WATER
Old Apr 26, 2003 | 11:32 PM
CatKrazy's Avatar
Default WHEN MY TAIL PIPE HITS WATER
IT KILLS THE POWER! AS SOON AS IT IS OUT I REGAIN IT. IT WILL START SPUTTERING REAL BAD AND ALMOST DIES,BUT AS SOON AS IT IS OUT IT WILL CLEAR UP AND RUN FINE. WHY IS THIS?
ALSO CAN I JUST SNORKEL THE TAIL PIPE ABOUT 6 INCHES AND NOT HAVE TO REJET?
THANKS
Old Apr 27, 2003 | 01:31 AM
Woody500's Avatar
Cat,are you sure that the plug wire is not your problem..It sounds like you are in deep enough water to get the wire wet..Try putting some Di-Electrical grease in the plug wire and I'm almost positive this will cure your problem!
Old Apr 27, 2003 | 01:34 AM
CatKrazy's Avatar
WOODY
ITS NOT THAT! I CANT SET IN WATER UP TO MY CARB AS LONG AS MY SPARK ARRESTER IS OUT OF THE WATER. I DONT UNDERSTAND IT MY SELF
Old Apr 27, 2003 | 01:42 AM
Woody500's Avatar
Thats kinda strange Cat..Does your bike idle low?If so try idling it up a lil bit..And yes you can add a exhaust snorkel without having to re-jet.You may only have to re-jet after snorkeling the air intake!
Old Apr 27, 2003 | 01:48 AM
CatKrazy's Avatar
YES I KNOW IT IS VERY STRANGE BUT IT HAPPERS ME IN DEEP WATER! IF I CAN EVER FIGURE IT OUT, I WILL HAVE THE BEST OF WORLDS AND ALL THE KINKS WORKED OUT
Old May 2, 2003 | 07:14 PM
Indiglo's Avatar
My cousin has the 500i and his muffler was loose at the clamps near the back just before the muffler...was giving him all kinds of grief, try tightening those, his keep loosening too so might have to watch them ;-)
Old May 2, 2003 | 10:38 PM
Cat500i's Avatar
Every bike Ive owned does the same thing, Ive gotten to where I take them to the muffler shop on the way home from the dealership as soon as I buy them now. I take them home, snorkel, lift and whatever before it ever gets dirty. Its alot easier when everythings clean and fresh.
Polaris SP500HO, 2 - Honda 450ES, Grizz600, Big Bear, Cat500i, ALL have done the same thing in deep water. The Hondas were the worst out of the bunch (smallest engine). Theres not enough back pressure to keep the water out of the muffler.
fordfaithful21
Dec 7, 2015 05:52 PM
Brandon400
Sep 7, 2015 12:20 PM
black_thunder
Sep 7, 2015 01:24 AM
Brandon400
Sep 5, 2015 08:44 PM
quickwhips
Sep 2, 2015 06:53 AM
