Lose Bolts!
Old Apr 27, 2003 | 09:48 PM
racerx5x5's Avatar
Default Lose Bolts!
I can't keep those nose plastic bolts that go into the tank on, Any good ideas?
Old Apr 27, 2003 | 10:20 PM
AZSAND's Avatar
THAT!!!!!Sounds down right sexy!
Default Lose Bolts!
When you figure that out let the rest of us know would you?
Old Apr 27, 2003 | 10:29 PM
brad650's Avatar
Default Lose Bolts!
put some of that lock tight on them
Old Apr 27, 2003 | 10:37 PM
PUSHINTHELIMIT's Avatar
Default Lose Bolts!
What I did was I took that bolt and clip bull$hit off and replaced it with an allen bolt and nut with a built in washer. i got the nut behind the plastic with a long needle nose pliers and held it with that while I tightend it up with an allen wrench. Looks good and no worries about comming loose.[img]i/expressions/face-icon-small-wink.gif[/img]
Old Apr 27, 2003 | 10:41 PM
racerx5x5's Avatar
Default Lose Bolts!
I thought I would try teflon tape.
Old Apr 27, 2003 | 10:58 PM
JMAC650's Avatar
Default Lose Bolts!
Use red loctite, and they wont come loose anymore.
Old Apr 27, 2003 | 11:07 PM
jetsnow600's Avatar
Default Lose Bolts!
i put on red loctite but when i went to take them out, one side spun itself a hole in the plastic threads instead of breaking loose the loctite, that was a pain in the **** to get off, dont use too much, lol. Sean
Old Apr 27, 2003 | 11:15 PM
lilnotts's Avatar
Default Lose Bolts!
you could always try blue loctite
Old Apr 27, 2003 | 11:28 PM
DuneMe's Avatar
Default Lose Bolts!
I used blue loctite (small portions) a couple times and it seemed to stay on the screws because they don't come loose and I don't use it anymore. Don't use too much on these or you won't get them off again.
Old Apr 27, 2003 | 11:54 PM
bigben's Avatar
Default Lose Bolts!
I just keep an eye on mine. I use hex bolts there, so when one does start coming loose I can tighten it a little by hand so it stays put until I get to a wrench.
Edit: Forgot to mention that the threads in the little clips in the tank cover are starting to get pretty sloppy on mine. I think I may have to come up with something more creative this summer. Those little bolts and my headlight (broke it again this weekend) are the only perpetual problems I have with my DS.
