400 overheating!
Old Apr 28, 2003 | 01:01 PM
Pechmial's Avatar
Default 400 overheating!
A few months back my 400 suffered a collision with my brother's 375. The damage to my 400 included the radiator. I removed the radiator and let the quad sit for a month while I raised up the money for the parts. Ever since the repair, the machine has had a tendency to overheat. There is plenty of fluid in the system (no leaks) and I've checked that the assembly was done correctly. Do these things have thermostats? Or am I missing something else that may have been damaged either by the colision or by sitting with no fluid in the system for a month?
Old Apr 28, 2003 | 02:28 PM
Kodiac400's Avatar
It really sounds like a thermostat issue. I'm pretty sure atv do have thermostats. If your not sure check with your dealer and they would be able to tell you for sure. If it is the thermostat maybe it dried up before you got it fixed.
Old Apr 29, 2003 | 12:51 AM
CatKrazy's Avatar
yes there is a thermostat built in to your assembly. thats what allows the fan to kick on and off. more than likley its sticking,get it checked out
Old Apr 29, 2003 | 11:41 AM
Bluethumb's Avatar
Sounds like something's airlocked.Try bleeding your cooling system before you go changing anymore parts. Good luck
Old Apr 30, 2003 | 09:39 PM
wanaberider's Avatar
The thermostat should be on the left side of the machine. just follow the hose and you should find it easy enough. I have heard of people cuttung the spring out so that it free flows. Hope its nothing major.
Jim
Old Apr 30, 2003 | 10:32 PM
Cat500i's Avatar
The most obvious question would be "is the fan running"?
Jenn1
Sep 8, 2015 09:16 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
MikeyBoyesq
Aug 10, 2015 11:11 AM
cornermike
Jul 30, 2015 06:37 AM
