Having a little raptor trouble
Old Apr 29, 2003 | 10:45 PM
polarisisthebest's Avatar
Default Having a little raptor trouble
The problem is when ever i am going really fast like fourth or fifth topped out for a while, once i let of the throttle and shift into one of the lower gears, my four wheeler starts to bog down and backfire or make a short pop noise in my exhaust, Then it will usually shut off. After this it take a while to get it started back up. This just started happening today. So any suggestions?
Old Apr 29, 2003 | 10:51 PM
PatsRaptor's Avatar
Didn't you get my pm?? Your too lean on your pilots! up them to 25.5 3 turns for NM
Old Apr 29, 2003 | 11:13 PM
Sorry pat i forgot all about calling you but i did get the PM. But i still need to up the pilot jets even with the stock exhaust? because i havent been able to order the pipe yet.
Old Apr 29, 2003 | 11:16 PM
PatsRaptor's Avatar
stock bike or did you put a K&N?? either way just adjust your air fuel out in 1/2 incraments untill the popping stops
Old Apr 29, 2003 | 11:24 PM
sixsixT's Avatar
Could be a sticky float.
Old Apr 29, 2003 | 11:30 PM
nope its an all stock bike, it seems like it is getting too much fuel or something?
Old Apr 29, 2003 | 11:35 PM
I also noticed that when i shake the four wheeler gas comes out one of the overflow tubes, I beleive they are called, by the top of the swingarm.
PatsRaptor's Avatar
Then sixsixt is right try tapping on the side of the float bowl if that doesn't work you will have to reajust them
95wolv
Sep 27, 2024 12:00 PM
bmxatv10
Oct 14, 2022 06:23 PM
mrtidy
Feb 3, 2016 05:00 PM
Clint Russell
Sep 25, 2015 03:20 PM
black_thunder
Sep 22, 2015 07:59 PM
