Crank case is leaking?
The crank case on my warrior is slowly leaking a little oil while sitting in the garage....Someone said i should re-torque the bolts, will this do it or does it need a gasket? I am planning on doing a oil change soon, what is recomended for this? thanks........
If it is leaking around the drain plug maybe it isn't tight. BUT do not over tighten it, trust me it can easily be done. If there is an o-ring there you might try replacing it. Other than that I don't know. I doubt that your cases started leaking, but I guess anything is possible.
WesTech
11
Aug 11, 2015 07:55 AM
Hankey Pankey
Jul 31, 2015 05:50 PM
