Crank case is leaking?
Old Apr 30, 2003 | 08:45 PM
oddmetal's Avatar
Default Crank case is leaking?
The crank case on my warrior is slowly leaking a little oil while sitting in the garage....Someone said i should re-torque the bolts, will this do it or does it need a gasket? I am planning on doing a oil change soon, what is recomended for this? thanks........
Old May 1, 2003 | 06:59 AM
Ward660R's Avatar
Where exactley is it leaking from? Did you do some work on it recently?
Old May 1, 2003 | 05:44 PM
oddmetal's Avatar
Its all stock and the motor has never been open. It doesnt leak alot but its moist near the drain plug and the seam of the motor. I have noticed the oil level slowly dropping.
Old May 1, 2003 | 05:49 PM
Ward660R's Avatar
If it is leaking around the drain plug maybe it isn't tight. BUT do not over tighten it, trust me it can easily be done. If there is an o-ring there you might try replacing it. Other than that I don't know. I doubt that your cases started leaking, but I guess anything is possible.
Old May 1, 2003 | 06:41 PM
RacinJason's Avatar
probably the crush washer beneath the drain bolt...
clean the underside well...run the quad and let it sit and see if you can track it down
Old May 1, 2003 | 06:58 PM
warrior86's Avatar
i second what raptorjay said!
Old May 1, 2003 | 10:36 PM
oddmetal's Avatar
Ok will do...thanks for the help
Old May 1, 2003 | 11:09 PM
warrior007's Avatar
Check to make sure you stock skid "bar" isnt pushed up into the motor. I have seen alot start to wear through the cases including mine which leaked a little between rides. .
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
WesTech
11
Aug 11, 2015 07:55 AM
Hankey Pankey
Jul 31, 2015 05:50 PM
Countrygirl1976
Jul 13, 2015 10:08 AM
