Please help ASAP!!!!!!
Old May 4, 2003 | 03:05 PM
Boxman's Avatar
Default Please help ASAP!!!!!!
I was getting everything lined out to go and hit the NOS. I had ran the quad, checked all my lines, etc. I killed the motor and was messing with my purge solenoid wires and all the sudden I have NO power at all. Could someone tell me where to start looking for a blown fuse, or whatever else it could be? This has never happened to me and I need some help locating the problem. There is absolutely NO power. No lights, fuel pump will not run, won't turn over. DEAD IN THE WATER!!!!! Any and all help is appreciated!!!!
Thanks guys.......Boxman
Old May 4, 2003 | 04:01 PM
ThePunisher's Avatar
Its your 25 amp fuse!!
Old May 4, 2003 | 04:12 PM
Boxman's Avatar
Where is it located? Thank you SO much ThePunisher!!!
Old May 4, 2003 | 04:17 PM
JSsDS's Avatar
When your quad was new the fuses were under the seat on either side of the air tube. They look like many of the other connectors accept they plug into a cap which is screwed to the frame. Pull the plug out of the cap and the fuse is on the end of the plug.
Old May 4, 2003 | 04:26 PM
Boxman's Avatar
Thanks guys...I feel like an idiot. As much work as I have done on this quad and haven't had to mess with the fuses!!! Right there in the old "owners manual" was a PICTURE!!! Thanks again ThePunisher, and JSsDS.
Old May 4, 2003 | 04:58 PM
Just call me Punisher![img]i/expressions/face-icon-small-happy.gif[/img]
Old May 4, 2003 | 05:33 PM
taitgt2002's Avatar
Sounds like blowing fuses is a common thing on these machines... Just seems like since I have been hanging around here, I have seen several posts when someone complains about not having any functions, due to an electrical problem. Are they that prone to failure, and are most of the problems easily fixable in the field?
Old May 4, 2003 | 05:46 PM
JSsDS's Avatar
I think that somehow you got the wrong idea of the Ds electrical system. There has been some oil and temp switch problems but not many shorts or blown fuses. The few fuse failures i'v seen were self induced, usually while hooking up some accessory.
Whenever a problem comes up where someone has no functions, the fuse is usually a suggested check but rarely the cause.
I think for the most part the DS has a very good electrical system. It deffinately has the highest stator output of any sport quad.
Old May 4, 2003 | 05:55 PM
Boxman's Avatar
I've only blown fuses twice.....both were self-induced. DS's are by FAR the best built sport quads on the planet!!!
"Punisher"....I like that. Can I adopt your name for a weekend trip to Aledo in June? LOL
Old May 4, 2003 | 07:26 PM
DemonDS's Avatar
I still like The Reaper!!!
