Dial a Jet and the V-Force
Old May 5, 2003 | 03:19 PM
NYVForce's Avatar
Default Dial a Jet and the V-Force
When you install the dial a jets on the v-force do you have to drill and tap the float bowls to install it. If anyone has installed them could you do a write up on it to help out those of us who are not familiar with them. Thanx for the help
Old May 5, 2003 | 05:24 PM
2lman's Avatar
I can't help you with the jets, but what do you think of your Elka's? I'm pretty sure I'm changing the front over but I'd like to hear what you think of them? What differences did they make?
Old May 6, 2003 | 12:44 AM
Vforcer's Avatar
NYVForce .... I did not have to drill the bowls. There are drain neddles in the bottom already, with a drain line
from each carb bowl teed together. I used an adapter to connect the short (existing) hose from each bowl to the
fuel line to the inductors. ( adapter because the hoses are different sizes ) ....... then I took the drain neddles out, and wrapped them with teflon tape ... and installed them again.... but did not "seat them".
Give me a call if you like ..... I will send you an email with my numbers.
STLyamwar
Jul 25, 2020 04:44 AM
polarisrider1203
Aug 29, 2015 07:52 PM
Mphillips
Jun 26, 2015 03:52 PM
newdsowner
Mar 21, 2001 02:49 PM
slickster
Nov 2, 2000 10:16 PM
