Small problem after jetting
Old May 6, 2003 | 03:04 PM
CatKrazy's Avatar
Default Small problem after jetting
I rejetted the needle today, Not spacers or washers came out,just the white clip looking thing and the needle,so i installed the new adjustable needle and set air mixture to spec and put my super trap back on. now when it idles it sounds like it cams. kinda idles up and down? Where is the problem out. Which part of the carb to I need to readjust!!
Thanks
Old May 6, 2003 | 03:32 PM
voodoo's Avatar
At idle it should be the pilot.
Old May 6, 2003 | 03:53 PM
CatKrazy's Avatar
So i can adjust the air mixture screw and get it right?
Old May 6, 2003 | 04:41 PM
voodoo's Avatar
Yes. Some get away with adjusting while the machine is running (depending on your tools) Could be an air leak as well. Re check your boots on either end.
Old May 6, 2003 | 04:52 PM
CatKrazy's Avatar
yea thanks man
I went ahead and rejetted, The pulg was very black and dry!
So i went from the 148 main to the 146, and set my needle down 1 more clip to number 2! Havent ran it yet but im fixing to fire her up!!!!
Old May 6, 2003 | 05:08 PM
Snochopper's Avatar
Main seems ok but I dont know if you'll need the needle to be that rich, usually you can get the Idle with the pilot (as mentioned). How many disc's are you running?
Old May 6, 2003 | 05:20 PM
Snochopper's Avatar
This is up in 35 mins, http://cgi.ebay.com/ebaymotors/ws/eB...tem=2413486276
Old May 6, 2003 | 06:17 PM
CatKrazy's Avatar
Im running 10 disc and SHE IS ONE BAD CAT!!!!
UNBElIEVABLE THROTTLE RESPONSE AND GREAT TOP END!!!!
I got her tunned right now!!!
PLUG LOOKS GREAT!!!!!!! STILL A LITTLE BLACKISH BUT LOOK SGREAT!!!
IDELS JUST PERFECT!!!!!
I fixing to take some pics of her
Old May 6, 2003 | 07:15 PM
voodoo's Avatar
Cool CK. Sounds like you got it! I dont know much about jetting the needle, mine you can adjust. My plug is very black. Carb is all stock. There are some great reads on here about it though. Better to have a little black on the plug to be safe. Sounds like the cat is better than ever!
Old May 6, 2003 | 07:19 PM
voodoo's Avatar
Damn it, No one bid on that muffler. I wasnt home and missed it! I am going to get the Super, the Megamaxx i will plug with water and mud for sure.
