Why raptor carbs are jetted different
Old May 7, 2003 | 03:07 AM
AustinONeal's Avatar
Default Why raptor carbs are jetted different
I herd that the carbs on a raptor have different jet sizes
Why?
Old May 7, 2003 | 03:24 AM
14mins's Avatar
Air- Fcr's come jetted the same on both sides from sudco.
I have noticed that running the same size jets on both side helps to even the exhaust temputure out, most i have seen are 50 degrees different from both sides.
But one side feeds 2 valves and the other feeds 1 is the reason, although you can take a trinity exhaust and seal off on side and the quad will still run. I used that as a example cause on day i removed the muffler and blocks off one pipe just to see. Trinity runs the headpipes seperate all the way to the muffler.
At least you have the lying down pat.[img]i/expressions/face-icon-small-blush.gif[/img] It just plain rips you that craycraft 686's can do you in. lol Maybe when you get back you will be able to adjust the chain properly.
[img]i/expressions/face-icon-small-wink.gif[/img]
Old May 7, 2003 | 01:54 PM
Thanks a lot airraptor fpr the information
could you tell me what the stock jetting is in the carbs. Sorry about all the questions just want to know
Old May 7, 2003 | 02:23 PM
Raptoryfn660r's Avatar
RIP Dear Friend
Here is a good ATV connection picture with a mirror on top of piston showing valves.
engine cut away picture
Old May 7, 2003 | 05:35 PM
DAMAGEINC's Avatar
the stock jet sizes are (sitting on the bike) left 140 right 145
Old May 7, 2003 | 11:47 PM
14mins's Avatar
Air- FCR's has a part number for the raptor in the sudco catalog, they come jetted 150, 150
A lot of people that run FCR's run identical jetting.
Old May 8, 2003 | 12:10 AM
ba01raptoraz's Avatar
I realize that one carb feeds 2 valve and the other carb feeds one. Does that mean that the one carb that feeds the 2 valves flows more air also to keep the A/F mixture correct?
Seems to me that the one carb that feeds one valve should be the oversized valve. The carb that feeds the 2 valves is trying to keep air flowing through 2 valves and one being enlarged. Seems like the velocity may decrease alot through that carb. Just some thoughts. I'm going to have to think about this some more.
Cole Hadden
Jun 15, 2025 09:05 AM
Reactant
Jul 16, 2015 10:29 PM
Dirtbikemike1
Technical and How-To Articles
10
Jul 12, 2015 07:22 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
black_thunder
Jul 9, 2015 05:58 PM
