Raptor stalls in wheelies
Old May 7, 2003 | 12:53 PM
JayBird04's Avatar
Default Raptor stalls in wheelies
Whenever i ride a slow wheelie(in first gear) my raptor putters as if it was going to stall. If I hurry and push the gas all the way in it slowly revs and quits puttering. But by that time, I have already came down off my wheelie. Is there something wrong with my float? I didn't even jet it. The only engine mod I have is a K&N air filter. Anyone else have this problem?
Old May 7, 2003 | 03:58 PM
JayBird04's Avatar
mbrp, I am not sure. I put the filter on awhile ago. How did he adjust his floats? Maybe that is what I should try?
Old May 7, 2003 | 04:09 PM
Vforcer's Avatar
My Buddy's did that ..... we adjusted the floats ..... he can ride a wheelie "forever" now.
Adjustment requires bending a little tab on the float .... in this case it would seem that
you need to "raise" the float level a bit . ( warning.... a very tiny movement makes big change)
Old May 7, 2003 | 04:14 PM
JayBird04's Avatar
Thanks for the info! Does adjusting the float effect the quad when you aren't riding a wheelie? Is there two floats because of the two carbs? Should I adjust both? Thanks again.
Old May 7, 2003 | 05:07 PM
Vforcer's Avatar
Yes to the adjusting both carbs ... there is one float in each ... and when the float is set correctly, you will not have to mess with it again.
Old May 7, 2003 | 09:40 PM
RaptorRidr660R's Avatar
I just had the same problem, it is the floats. You need to adjust them so that the fuel level in the bowl is just a little over where the bowl and carb base meet. To check your level put a clear hose where the black drain hose is on the bottom of the carb, then loop it up next to the carb and open the drain screw. it will fill up to the fuel level and you can see how high it is that way. Like I said, you want to adust the floats untill that level is right around 1/8" above the bowl mating surface. Mine was like 3/8" at first and would die doing wheelies, I did the float adjustment and problem solved. Good luck
Old May 8, 2003 | 10:58 AM
JayBird04's Avatar
Thanks again! I will definitely have to try that this weekend.
Old May 8, 2003 | 05:25 PM
trapland's Avatar
RaptorRidr660R, What an EXCELLENT tip! It makes perfect sense. Got anymore like that?
Old May 8, 2003 | 08:07 PM
Vforcer's Avatar
what an absolutely perfect answer ....... Well done RaptorRider ....!
BTW ..... I am wondering if I met you once at North Gate Tire ????
Old May 8, 2003 | 08:11 PM
mich660griz's Avatar
on the grizzly's, the same thing has happened to many, when comming out of a hole on a steep bank. in other works, in high rises. the dealerships have adjusted all the floats 2mm on the carbs, and solved peoples problems. sounds like the same problem.
