300 Bayou Backfire's and Engine noise
Old May 9, 2003 | 12:43 AM
Rayman5000's Avatar
Default 300 Bayou Backfire's and Engine noise
Hello..i have a 2000 Bayou KLF 300 that has low hours on it...When i start the engine up it starts up fine with the choke but as i take off the choke it start's to run terrible and backfires thru the carb and as it backfires...something makes a loud bang or a clunk from in side the engine.The things that i had checked so far is Valve clearence and i cleaned out all the jets in the carb.Then set the air mixture screw while it was running.Anybody have a idea what it might be as i don't have a clue what could be causing the problem...i don't want to dissasemble the whole enige if i don't have to.. I would appreciate any advice...Thanks.
Old Sep 15, 2003 | 03:28 PM
kawrules's Avatar
I know this sounds off but sometimes a bad battery will cause that, even if it starts the engine ok.
Old Sep 15, 2003 | 03:43 PM
KAWIMECH's Avatar
again the voltage regulator could be going bad and if not taken care of it will destroy the ingniter and cause intermitent spark
Sjrpp
May 2, 2023 03:59 PM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
Sjrpp
Jul 5, 2015 09:04 PM
D-Hagz
Jul 4, 2015 02:19 AM
