Warrior Reverse Question
Old May 1, 2000 | 09:38 PM
1BadWarrior's Avatar
I was just cruising around today on my Warrior and I went down over this bank that has a pond right after you start down the bank. I know the pond was deep so I stopped and put my Warrior in reverse. When I went to go it wouldn't move so I pulled in on the clutch and then I heard a clunk noise and then I tried to go again and it moved. Does anyone else's Warrior do this?
Old May 2, 2000 | 01:10 AM
20warrior00's Avatar
It sounds like you did not have the reverse lever fully engaged. Make sure you move it all the way back and you should not have a problem.
Old May 4, 2000 | 04:15 PM
lastwarrior's Avatar
the reverse lever is one of the warriors few problems . sometimes it will not sit properly causing it to just sit and grind.
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
manuelrivera
Aug 8, 2015 04:34 PM
suzukiquadrunner1987
Aug 6, 2015 05:29 PM
Ashley S
Jul 31, 2015 09:46 AM
