Drag Racing Help Needed!!
Old May 9, 2003 | 11:35 PM
jerstilly's Avatar
Default Drag Racing Help Needed!!
I was racing a few buddies the other day(one banshee, one Z400) and while racing i could be the banshhe, but the z400(stock), would keep right there, he got much better holeshots and just pulled from the start. Do you guys have any tips for racing, the start(what gear) how high you reving the engine etc etc, and whats the best way to switch QUICK. thanks for the tips, i want to learn so i will be on the BETTER side.
Old May 9, 2003 | 11:40 PM
DollarBillz's Avatar
WHAT ARE YOU RIDING
Old May 9, 2003 | 11:42 PM
jerstilly's Avatar
Sorry, totally forgot, duhhh, 02 raptor stock evrything
Old May 9, 2003 | 11:47 PM
START OFF IN SECOND GEAR, THAT HELPS A LOT. JUST SIT VERY FAR FORWARD AND DUMP THE CLUTCH AND YOU SHOULD LAUNCH GOOD. IF YOU ARE BEATING A BANSHEE, YOU SHOULD HAVE NO PROBLEMS WITH THE Z400.
Old May 9, 2003 | 11:49 PM
jerstilly's Avatar
How much throttle are you giving it when you are dumping the clutch, and whats the quickest and best way to shift, thanks a gain
Old May 9, 2003 | 11:50 PM
87Banshee250sx's Avatar
Beating a shee and not a z400? something smells fishy.. unless you are on grass or something
-nick
Old May 9, 2003 | 11:55 PM
YA I DON'T SEE HOW YOU ARE BEATING THE SHEE BUT NOT THE Z400. UNLESS THE RIDER ON THE 400 IS A SUPER EXPERIENCED RIDER AND YOU AND THE GUY ON THE SHEE ARE JUST STARTING OUT, YOU SHOULD HAVE NO PROBLEMS. TRY NOT HOLDING THE GEARS OUT AS LONG BEFORE YOU SHIFT. IT'S GONNA BE TRIAL AND ERROR TO SEE WHAT WAY WORKS THE BEST FOR YOU
Old May 10, 2003 | 12:02 AM
jerstilly's Avatar
yes me and the friend on the banshee are around the same riding ability, but the guy on the Z400 has been riding quads 4EVER, so how much throttl when dumping the clutch in 2nd gear on the start.
Old May 10, 2003 | 12:05 AM
TyreSpinner's Avatar
as much as you can without over-revving or standing it on the grab bar when u dump it. Just start lower, then move up.
[img]i/expressions/face-icon-small-smile.gif[/img]
Old May 10, 2003 | 02:05 AM
BigScary's Avatar
drop a tooth on the front or gain one on the back............start off in second...........put all of your weight up on the bars.........and sit down after the tires start to grab!.........
das what I do.....and I seldom get beat.......
MikeyBoyesq
Nov 27, 2020 02:44 PM
jrooker6
Ask the Editor
11
Apr 21, 2016 07:35 PM
blackmagic
Feb 26, 2000 09:27 AM
