How fast would my lt-250 be with these mods
Old May 11, 2003 | 08:36 PM
lt250rider's Avatar
Default How fast would my lt-250 be with these mods
how fast would my lt be with a fmf fattty pipe, coold head, wiseco piston, v-force reed cage, k&n filter, and a 13 tooth front sprocket.
Old May 11, 2003 | 09:36 PM
2000blasterbeater's Avatar
you'd lose a ton a overal top speed by gearing down
If you left it stock geared i'm sure you'd top out about 75?
You'd be quick with the 13 tooth tho!
Old May 11, 2003 | 10:39 PM
LT250R87's Avatar
A 13 tooth front sprocket will make it faster not slower because the stock front sprocket has 12 teeth. Going up on the front sprocket gears up. Going up on the rear gears down. A brand new stock machine tops out somewhere around 74 acording to a dirtwheels test. With these mods and gearing up, you should obviously expect to go faster than that.
Old May 12, 2003 | 09:18 AM
HUEDOGG's Avatar
no the zuki would smoke it! but i would smoke them both!
Old May 12, 2003 | 01:50 PM
DodgeCara270r's Avatar
I think that your atv would hall ***!!!!!!!
Old May 14, 2003 | 07:35 AM
Icehouse's Avatar
Stock front sprocket is 12 teeth so 13 will give more top speed but less bottom end, personally i use 12 teeth so I can leave harder in second gear. The mods you mentioned will definately make your lt faster. HOw much hp depends entirely on the condition of your engine. THe pipe/sil/filter combo will get you about 6 hp, reed cage will improve throttle response which is as good as hp, and compression increase from a cool head will give you a couple more ponies at best. A stock lt has i believe 26 hp so youd have less than 35,but its really impossible to tell. Even dynos can be misleading, from machine to machine. I had a pro circuit pipe and purchased an LRD. If you intend to buy a pipe id wait till you had the money for an LRD its worth it.
Pehter
Oct 3, 2024 11:00 PM
ReconBayou
Oct 31, 2022 05:37 PM
Sep 23, 2015 06:23 AM
PrairieDog126
Sep 16, 2015 01:33 PM
1ArmBandit
Sep 8, 2015 08:59 PM
