Rear foot brake problems.
Old May 12, 2003 | 01:14 PM
alcoff95's Avatar
Default Rear foot brake problems.
I've been hearing a rear clanking noise coming from the rear axle of my `03 500i. Upon investigation I found that the rear mechanical foot brake is dragging the inside pad. The pad looks like it is worn considerably more than the other. I only have about 150 miles on it. I tried adjusting the cable but that only made the brake work worse than it already does. Has anyone else had similar experiences with the rear foot brake? I was thinking I should take it to the dealer for warantee work, but if this is how they all work, I was thinking of just removing it and trusting my well being to the main brakes.
Any others care to share their experiences/ opinions?
Old May 12, 2003 | 02:24 PM
mudblaster's Avatar
my rear break squeeked all the time it drove me nuts and when i tryed to use it it barly worked so i took it to my dealer and thay ajusted it for me, now it works better but it still squeeks but not as much. I would take it to your dealer and see what thay can do for you maybe it was set up wrong rite from the start and wore your pads down, talk to your dealer and see what thay say. if you still got warrenty thay should fix it no matter what the problem is
Old May 12, 2003 | 02:54 PM
voodoo's Avatar
Rear brake = remove. Mines been useless since day 1, so i took it off.
Old May 12, 2003 | 04:45 PM
Pechmial's Avatar
I'm with VewDew, remove the darn thing. Mine actually broke when I was using it to add some "drag" when re-tensioning the winch cable. It's about $100 to replace so I said "forget it" and haven't missed it once. 'Spose I'll need to replace it soon, though, as I'm planning on selling the darn thing.
Old May 12, 2003 | 11:11 PM
greasmky's Avatar
mine broke when i got a rock inside the wheel and it broke the caliper into so i just took it off didnt work that great any way
2002 375 auto 4x4
custom front bumper w/ 2000#winch
itp589ms
custom rear bumper(in the works now just need the time to weld it)
SixSpeed5
8
Aug 2, 2015 05:38 PM
willday08111217@gmail.com
Technical and How-To Articles
Aug 1, 2015 04:05 AM
Sandman2.0
Jul 21, 2015 09:03 AM
timster911
Jul 13, 2015 01:57 PM
