Will it ever go straight?
Old Aug 7, 1999 | 06:37 PM
MiNdZ's Avatar
When i ride down anything that is falt and straight my cat wanst to go to the left...i have checked air pressures... adjuted tir rods and had the dealer look at it....does anyone have any ideas? also if you like juump up and down on it u can hear somthing like knocking...ive narrowed it down to the suspnsion but i still can figure out what it is..any ideaS?
Old Aug 7, 1999 | 07:28 PM
Robert Venable's Avatar
I know what you mean. When I ride mine on the road it pulls to the right.
What do you mean by "knocking".
Do you have any modifications to your 500? They could be causeing this.
Arctic Cat 500, Not your average Kitty, The New King Of the Jungle
Old Aug 8, 1999 | 12:34 AM
MiNdZ's Avatar
Everything is stock except ox light brush gaurds,....i have seen where they have rubbed a little against the frame....Also the paint on my floorboards is rubbing offf bad and i dont want it to rust you got any ideas?
Old Aug 8, 1999 | 01:19 AM
Unbolt your racks, floorboards, and front bumper. Tape up the mounting holes Take them to a Line-X dealer and get them "bedlined". There is oonly one problem. It will probly cost around 200 bucks for everything. I will be doing this as soon as i get the money.
Old Aug 8, 1999 | 01:36 AM
MiNdZ's Avatar
Line-X???ever heared of..what do they do coat it in plastic?Have you had any proublms with water gettin in your rear differatiol? i keep geeting the milky color and when i drained it it had like dirt around the bolt you drain it form...was te dirt(i dont really think it was dirt it was like fine grineded metal..not alot just maybe the size of a water droplet)
anytihing i should worry about and are the seals waterproof?
Old Aug 8, 1999 | 03:18 AM
You know, spray-on bed liners.
Never had water in the differential. My dealer says he has never had found water in any Actic Cat's oil. the first thing you should do is change the ooz-it, that funny looking plastic thing.
Old Aug 8, 1999 | 10:11 PM
MiNdZ's Avatar
I was wondering if it could be leaking in there....What did you replace it with?
Old Aug 9, 1999 | 01:26 AM
Replace it with another one if it's cracked. If it is not cracked or damaged bring your quad to the dealer and have them check it out.
MikeyBoyesq
Sep 22, 2015 10:02 AM
Canamaniac!
Sep 15, 2015 06:19 PM
meddy0388
Sep 9, 2015 06:41 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
Brandon400
Sep 5, 2015 08:44 PM
