Cat will Not Start
Old Jul 16, 2003 | 11:40 AM
snafu's Avatar
Default Cat will Not Start
2002 250 Cat-Cat will not start with key,Have juice to fuse box but only
juice on one side of ignition fuse,(all other fuses are good)Have replaced fuse and still have problem.I can start the Cat if I run a wire from the battery plus side to the bad side of fuse,the key has no effect
just pull off the wire and the Cat stops running.Has anyone ideas what could be wrong?
Old Jul 16, 2003 | 11:39 PM
Bigcat's Avatar
snafu
Check by the steering, where all wires go down the steering post. You will see a 3 prong wire that goes to to the igniton, it might have poped loose. This a common problem, make sure the wires have lots play when you turn the steering , left to right. I hope this helps...
MikeyBoyesq
Nov 27, 2020 02:44 PM
Mkp
Mar 28, 2020 03:50 AM
tiresharkdbb
Sep 3, 2017 02:06 AM
garyt1975
Jun 5, 2015 08:53 AM
1000gade
May 27, 2015 12:37 PM
