Arctic Cat dependability?
Old Oct 8, 2003 | 09:09 PM
  #21
Cat500i's Avatar
Default Arctic Cat dependability?
You forgot to mention to replace the rear axles after every ride!!
Old Oct 9, 2003 | 02:50 PM
  #22
cpalm1's Avatar
my cat 500 has been very reliable. only problem was a sparkplug that broke after 200 miles, and they forgot to plug in the radiator fan at the factory. the shifter is also rough, but has gotten better. I don't think my next quad will be a cat simply because i want something a little smaller and lighter. my friend has a polaris sportsman and i think it is much more fun to drive. I have 2 honda 3 wheelers, and they are amazingly reliable. i wanted to buy a honda quad, but that year they only had electronic button shift, which i didn't like, so i bought the cat.
Old Oct 9, 2003 | 03:09 PM
  #23
mudblaster's Avatar
i've only had to have one axle replaced.
since then i've had no problums with it.
and that was over 400 miles ago
i realy like my cat so what if it has a few problems.
when they get them all ironed out it will be one sweet ride.
i still think its one of the best quads out there and it will just get better.
every quad has it querks.
cat500i you must have gotten a monday cat eather that or your very hard on it.
did your dealer not fix yours under warrenty.
im not trying to **** you off but i ride my cat in all kinds of terrane and i have 1400 plus miles on it and only had probs with one axle and it dident break it was just starting to make a clicking noise and the warrenty covered it.
Old Oct 9, 2003 | 03:49 PM
  #24
luvthemud's Avatar
speaking of that. i just got my quad back from getting the new axle put on. The new one is different then the old one. Skinnier in the middle and then it bows out at the ends. i called the dealer back and said that those are new, my quad was the first one he has put one in, so maybe they have figured out their axle problem?!?
Old Oct 9, 2003 | 04:28 PM
  #25
Olddirtybastard's Avatar
luvthemud, the skinny axles are the 04s, they are stronger. I happen to know a little about them, having broke 5.
Old Oct 9, 2003 | 06:17 PM
  #26
mudblaster's Avatar
my new axle is the same as your new one.
Old Oct 10, 2003 | 02:39 PM
  #27
Scrmblerman's Avatar
1wook, I didn’t know Consumer Reports talk about ATV’s?? I looked in the index of one didn’t see anything on ATV’s…
Old Oct 11, 2003 | 02:05 AM
  #28
luvthemud's Avatar
hey ODB, will it be OK running a 2003 axle on the left and a 2004 on the right. will it cause any type of problems at higher speeds?
Old Oct 20, 2003 | 02:34 PM
  #29
1wook's Avatar
I don't know what issue it was, pretty sure it was consumer reports. I was reading it at the bank while waiting, about a year ago.
Old Oct 20, 2003 | 03:37 PM
  #30
I just read the post. Having the different axles will not cause any problems.
