Mudlites on 2004 400 ACT?
Old Apr 11, 2004 | 03:56 PM
UpandOver's Avatar
Default Mudlites on 2004 400 ACT?
I just bought a 2004 400 ACT and really like the ATV but the tires really tend to roll when pushed hard in the corners. I have read a few posts on the Mudlites and they have many good reviews. The question I have is that my stock tires are 25X8X12 front and 25X10X12 on the back. Can I go to a 26X10X12 on the front and 26X12X12 on the back? Will these tires rub on the frame? Also can these 26" mudlites be put on my stock rims that I have? Last question will the bigger tires make me loose some speed or will it be overcome by the extra traction. I mostly use my bike for hunting and travelling in the mud. Thanks
Old Apr 11, 2004 | 04:11 PM
Bluethumb's Avatar
How ya doin'? I have the same bike as you, only it's a '03. I just put 27" Bearclaws on mine and it made a drastic improvement in the handling, and getting the power to the ground. I used stock rims, and being 12" in the back , they hit the rear springs. I got 1" Highlifter aluminum spacers, and this solved my problem. The ACT has the shock/springs mounted more vertically as opposed to the IRS, which are tilted inboard more and clear bigger tires without spacers. I did find slight power loss, but nothing really substantial. I went to 27" because the 26" Bearclaws were actually heavier. Mudlites seem like a good choice, I considered them, but they had the same round face as the stockers, where Bearclaws were more of a flat faced tire. Whatever you decide, if you go with 12" rear tires, they'll probably hit, if any bigger than stock. I don't think they rub enough to cause any damage, but I put spacers on cause I didn't like the sound of it rubbing. Cheers
Old Apr 12, 2004 | 04:43 PM
MACHZMISSLE's Avatar
My pops has 27x10 gators front and back and they work fine on is 04 400. I was looking into a 400 act cat and woulda put 28inch Mudzillas on. There is plenty of room for 26's.
Old Apr 13, 2004 | 03:30 AM
akfireman's Avatar
I have 26" mud lites and I have no problems with my 04 400i.
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
2many2ride
Sep 27, 2015 04:35 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Bernhard
Sep 25, 2015 12:45 PM
Sw00p
Sep 24, 2015 02:50 PM
