Clunking noise on 04 400
Old Jul 21, 2004 | 03:09 PM
mtnman1's Avatar
Default Clunking noise on 04 400
Have an ac 400 and when riding the trails, hear a clunking noise from the rear??? Inspected for loose parts etc. noticed that the inside of the rear rims are scored.Like they are rubbing. The shock is extremely close to the rim and beleive that is the problem. Anyone else notice this or is it just me??? Is there a way to fix this??? Will be taking it back to the dealer but would like to get some input to find out if others are experiencing the same problems. If so will try and have ac cover it.
Old Jul 21, 2004 | 05:02 PM
1wook's Avatar
If you hear a clunking when you let of the throttle or going down a hill it is ussually the sound of the play in the driveline as the enginge braking kicks in. The sound is normal. I sometimes get gravel in behind the rear brake disc and wheel, it has rubbed off the paint.
Old Jul 21, 2004 | 06:31 PM
mtnman1's Avatar
I hear this noise when going over bumps at high and low speeds, not when letting of the gas or applying.
Old Jul 21, 2004 | 08:00 PM
vrz500tbx's Avatar
is the rear brake caliper rubbing on the inside of the rim?
Old Jul 21, 2004 | 11:16 PM
mtnman1's Avatar
I beleive at some point it is and think that is where the noise is coming from. There is probably a quarter of an inch (if that) between the shack and the rim. Just wondering if anyone else has this same problem or if something is not right with mine??? Possibly not put together right or something??
mrtidy
Feb 3, 2016 05:00 PM
Ahtatu
Sep 28, 2015 12:14 PM
kbazzy
Sep 26, 2015 11:26 AM
firsttimerider
Sep 20, 2015 09:07 PM
