stump pulling
Old Aug 21, 2000 | 02:20 PM
tirofog's Avatar
Hi, I was out this weekend pulling pine stumps (6in.dia.) with my 500 auto. I must say I was suprised that I pulled all but two stuburn stumps
I had no idea how much power these atv's had!
I am worried though, if I keep using the rear hitch with a clevis and chain, will I damage the rear differental, as the hitch is only secured by four bolts to the diff. I am careful not to jerk a hard load and I use low range only.
Thanks much!!!
Old Aug 21, 2000 | 09:43 PM
cowboy's Avatar
Tirofog:
I just got in from up at the property. Been up there since friday afternoon doing nothing but pulling logs and stretching fence. I took two pieces of flatbar steel ~1/4" thick and put on both the top and bottom of the hitch plate, then mounted a standard 2" ball through that. I then drilled out 3/4" holes strait through the flatbar steel which now sticks out about 3" or so, which is where I mount my clevis too. I've got the option of either the ball, or the clevis to tow with, which works out great. Normally when I tow all these logs and fence posts around, I'm in 4 wheel, low range. As long as you're not "jerking" too much, I don't see how it would be a problem. I've pulled some pretty large logs up hills with no problem at all until the log I am towing hits a stump or another tree, which then stops me dead in my tracks. Actually what happens is all four wheels bury themselves so I have to back up and out of my four holes I've just dug, then go at it from a different angle. As long as you're in low range, I don't think you'll have any problems at all.
Good luck, happy stump pulling!
Mike
donintennessee
Jan 8, 2021 12:40 PM
SDR-II
Sep 29, 2015 01:06 AM
sweaver
11
Aug 18, 2015 03:47 PM
jldominic
Honda Side by Sides
Aug 8, 2015 06:54 PM
JoAnnS
Jul 23, 2015 02:18 PM
