Arctic Cat 90
Old Feb 21, 2005 | 04:06 PM
shannagon1's Avatar
Default Arctic Cat 90
My dad recently got my little brother a 2002 Arctic Cat 90. It cruises pretty well and we want to put a headlight on it. Does anyone know how it would be possible to get a headlight on it?
Old Feb 21, 2005 | 09:08 PM
Bear4570's Avatar
You might try the Kids Quads forum.
Old Apr 19, 2005 | 10:00 AM
racedad21's Avatar
So how is that 90cc A/C working for you? We have one also--just looking for your thoughts.
Old Apr 19, 2005 | 10:51 AM
spike99's Avatar
To obtain more details of less then 125cc ATVs, surf: http://forums.atvconnection.com/cate...m/catid/10.cfm
To answer your question, yes. Lights can be installed on an AC-90. Single or dual front lights. Many say the stator system on a mini can produce up t0 35 watts. Thus, try to use bulb sizes that are under 12V - 30 watts. Say, 1 x 20w (MR16-20W) or 2 x 15w. For quick install, run wire from"+" side of battery to inline fuse (6" - 8" from the battery), into an automotive toogle switch, then wire into the headlight(s). Clean and simple "hard wire". If wondering, this is the same wiring diagram I used to install a Reverse Light on my AC 500i. Works great.
For pictures, surf:
Dual Front lights & combo tail light on our mini:
http://community.webshots.com/album/283371980xEWfck/0
http://community.webshots.com/album/283371980xEWfck/1
Reverse light on our AC 500i:
http://community.webshots.com/photo/...64288091DrjYnN
http://community.webshots.com/photo/...64288299urkFwc
http://community.webshots.com/photo/...64288569FmGGYT
Good luck!!!!
Old Apr 19, 2005 | 12:19 PM
Cmymud's Avatar
The AC 90 has a position for lights on the key switch this is how you can run the tail light.
I have not done the Mod yet but I think you can run off this switch.
Old Apr 19, 2005 | 03:00 PM
spike99's Avatar
Yes. You can connect Light wiring to an ignition switch. Since Switch wiring is usually small guage, it's best to install a 12V Relay. A universal relay is only $3 - $7.
For more details, surf: http://community.webshots.com/photo/...26333595xURZQx
Hope this helps...
Old Sep 23, 2011 | 09:11 PM
ArcTic cat 13's Avatar
can i hook a headlight to the white connector?
Customer Service #1
May 15, 2020 08:46 AM
shimanok2
Jan 29, 2016 07:37 PM
brad patnoe
Sep 23, 2015 06:44 PM
vtech
Help With Forum Software!
Sep 2, 2015 05:59 PM
Sep 1, 2015 01:45 AM
