1998 500
Old Jun 18, 2005 | 09:58 AM
robin's Avatar
Default 1998 500
I just purchased a 1998 500 arctic cat,When i checked it out i noticed play on the left rear axle.Can any one tell me what could be wrong. It has 1600 miles on it.
Old Jun 18, 2005 | 11:50 AM
Bear4570's Avatar
Default 1998 500
What kinda of play? In and out? UP and Down? Play doesn't say much but probably a bearing bad, if not in and out. Easy fix, replace it.
Old Jun 18, 2005 | 08:42 PM
robin's Avatar
Default 1998 500
Hi;
Up and down quite a bit of up and down .I think it is the outer bearing, Hope it didn't score the axle.
Old Jun 18, 2005 | 11:35 PM
Bear4570's Avatar
Default 1998 500
Bearings get water in them on these things because we insist on riding them the water and no seal is perfect after the new wears off. If the bearing didn't seize (only hear of one doing that) then it is just a matter of removing the axle nut, pull the hub and if necessary remove the knuckle to get the old bearing out.
Old Jun 19, 2005 | 12:42 AM
ridinsmooth's Avatar
Default 1998 500
i think if you puta new bearing in it will be good as new
Slagpolaris
Sep 5, 2015 09:41 PM
clsharky
Jul 13, 2015 02:07 PM
honda71
Jul 12, 2015 05:56 AM
honda71
Jul 8, 2015 02:13 AM
