K&N Air Filter
Old Dec 18, 2005 | 08:45 PM
191145's Avatar
Default K&N Air Filter
Should I replace the stock air filter on my 06 AC 400 Auto with a K&N air filter? Would it be worth the $47.65 that Fox performance sells them for? Thanks for any feed back.
Old Dec 18, 2005 | 09:46 PM
Hoopie's Avatar
Im a big k&n fan but for the cats if you do mudding\water riding i would stick with the stock. they protect from the elements better with that thick foam they have. IMO
Old Dec 19, 2005 | 01:41 AM
Cattywompus's Avatar
Well I have one for my 05 400 and I haven't noticed a difference compared to stock, I would suggest buy a moose or UNI and 2 prechargers to cover them to help cut down dust. this way you can service one and let it dry and still ride using the other. I swap from KN to stock durning cleanings.
Old Dec 19, 2005 | 02:17 AM
Bear4570's Avatar
I know a guy running a pair of K&Ns without an airbox with outerwear covers and he has had no water problems. Running one in an airbox should present no water problems and with the outerwear or a precharger the service life should not be any worse than the stock unit. The K&N will flow air better than the stock filter, but without an exhaust system or exhaust mod to move the air out of the engine quicker, probably not much of a power boost if any.
Old Dec 19, 2005 | 03:00 AM
rescuediver's Avatar
We run k&n's on our bikes. I even run one on our mojave that is a clamp on with one outerwear. It's been through creeks and ran in the rain without effecting the performance of the filter. Now, that doesn't mean you can take it into a deep mud hole or high creek/river. You still need to use common sense on where/when to ride.
Old Dec 20, 2005 | 01:41 PM
191145's Avatar
Hoopie,Cattywompus,Bear4570,Rescuediver: Thanks alot for sharing your expertise with me in reguards to my K&N air filter question. I hope ya'all have a merry Christmas and a properious New Year.
Old Dec 20, 2005 | 02:49 PM
You too, No problem and good luck
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Steeldon
Sep 9, 2015 09:38 AM
black798
Sep 9, 2015 07:42 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
