Adjust shocks with heavy plow?
Old Dec 22, 2005 | 12:40 AM
Maule180C's Avatar
Default Adjust shocks with heavy plow?
Hi all.
I have a relatively new (76 miles; still no 1st service yet) 2005 500 Auto with 2500# Warn and a Moose 60" plow. As many are aware, the Moose plows are built like a tank with thick 11-gauge steel and it must weigh at least 120 pounds. When the plow is raised up, the nose of the ATV drops noticeably. The front shocks are in their default factory setting.
Should I use the spanner wrench and adjust the front shocks so they're more firm when plowing? For what it's worth, when the plow isn't mounted I generally ride on flat trails but occasionally climb over a downed tree.
Thanks!!!
-maule
Old Dec 22, 2005 | 01:11 AM
IdahoVinnie's Avatar
Definitely stiffen them up. That's exactly what the adjusters are for. When you trail ride, simply adjust them softer. That's why they are made to be so easily adjustable.
Old Dec 22, 2005 | 01:34 AM
Bear4570's Avatar
Be aware that with weight on the shocks, the adjusters are very stiff amd will break the wrench. Either jack the wheels off the ground or use a pair of large slip joint pliers, then you don't have to jack it up. A squirt of WD-40 on the adjusters will help also.
Old Dec 22, 2005 | 01:40 AM
Just lower the blade with slack on the cable, to lessen the weight on the suspension.
Old Dec 22, 2005 | 01:44 AM
Bear4570's Avatar
The factory wrench will break with the machine's weight only on the shocks.
Old Dec 22, 2005 | 09:11 AM
Theshonk's Avatar
Try a small pipe wrench or channel locks
Shonk
Old Dec 23, 2005 | 11:20 PM
liquidplumber's Avatar
Bear is correct factory wrench is a POS
Old Dec 24, 2005 | 08:14 PM
WhoDatInDaMud's Avatar
I put heavy duty springs on the machine. The "adjuster" wasn't enough. The adjuster does change if from woosey to whimpy but it needed more. Highlifter sells HD spring kits.
ylomnstr
Sep 22, 2015 12:19 AM
Steeldon
Sep 9, 2015 09:38 AM
craacker
Sep 9, 2015 04:32 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
ylomnstr
Sep 4, 2015 05:02 PM
