Need help with AC 650 2005
Old Dec 31, 2005 | 10:17 PM
elkster23's Avatar
Default Need help with AC 650 2005
Electric starter doesn't work. The neutral light does not come on. If I can rock the machine and get the neutral light to come on then it works....any suggestions on how I can fix this...it is a bear to hand pull that 650 over...
Thanks...
Dave
Old Jan 1, 2006 | 12:13 AM
SPD522's Avatar
Sorry but I have to ask this. You are pulling the handbrake or stepping on the foot brake when you try to start it aren't you?
If that isn't the issue, it is a problem best handled by the dealer. Warranties and stuff.
BTW, welcome to the forums and Happy New Year.
Craig
Old Jan 1, 2006 | 01:08 AM
Bear4570's Avatar
If the machine is not in neutral it will not crank, unless you have a brake (either hand or foot) on (the brake light has to come on). The neutral problem is a shift linkage problem and your dealer is the best one to handle that.
salixair
Nov 3, 2015 08:25 AM
01ssls1
Sep 22, 2015 06:50 AM
Lou Domenech
Sep 11, 2015 06:35 PM
Brandon400
Sep 5, 2015 08:44 PM
