Keeping Plugging Tire or Replace It?
I have had my first ATV a couple months and had to put 3 plugs in the rear rear tire today for the same hole. Should I replace the tire because it took 3 plugs to close the hole or do you think the plugs will hold?
Put SLIME in the tires and that should take care of the problem. Slime will plug up to a 1/4 hole. And in a case were the hole is larger the plug will reduce the hole size so slime will work.
I usually send my tires that need more than 1 plug in the same hole to a tire shop and get them vulcanized which is a hot patch that is forced into the hole . Its a permanent fix that you dont need to worry about each time you take a ride. The cost up here is about $20 per hole
Question: If you need to replace a tire on a quad due to a bad hole or tear, do you need to replace all of the tires? On most 4x4 road vehicles, the tires have to all have the same amount of wear, so if you have to replace one, you have to replace them all. Or else your running the risk of tearing up a transfer case. Any thoughts?
Im with weez on this one. tubes work better than plugs and better tires are they way to go anyways.
