brake kight problems
Old Oct 12, 2006 | 07:33 PM
airforcedad's Avatar
Default brake kight problems
i have a artic cat 250 4x4 the brake light does not come on when depressing the hand brake .
the foot brake works fine
besides a broken hand brake switch what else would cause this problem
i purchsed it as a floor model in april of this year and its still under warranty
should i bring it in for service or does this sound like a non warranty issue?
Old Oct 12, 2006 | 08:00 PM
Bear4570's Avatar
Switch is bad in the hand brake or the plug came apart down below the steering head (just follow the wire down from the switch) under the front plastic). I guess it could be a broken wire but I've never heard anyone complain of a broken wire. I was an Air Force dad another life time ago (pre 1975).
Old Oct 12, 2006 | 08:30 PM
TORK's Avatar
Would almost bet that it is unplugged. Wires go down next to column and have a couple of tabs that hold them, when you turn if they are to tight it unplugs them.
Old Oct 12, 2006 | 09:32 PM
i have twins who both lt. s on active duty
Old Oct 12, 2006 | 09:38 PM
Bear4570's Avatar
Well, to ohms check the switch you have to find the plug. So that is easy way to start checking. I agree however, that it is probably unplugged. I did it once just by reaching in and rerouting the tank vent hose. Sure doesn't take much.
toonces
Oct 16, 2019 12:11 PM
Sandman2.0
Jul 21, 2015 09:03 AM
Chuck188
Jul 17, 2015 02:45 PM
timster911
Jul 13, 2015 01:57 PM
sublime250
1) Engine problems..
Jul 11, 2015 11:52 AM
