500 and mud and dirt in the intake
Old Oct 26, 2006 | 10:04 PM
HickFisher2005's Avatar
Default 500 and mud and dirt in the intake
Ok, after getting my quad completely clean and finally making it to the airbox, i noticed that there was water and dried mud in there to. There was more mud in the hole closest to the front, and a lot less in the bigger one, but some in there none the less. I know this has to get cleaned out of there, what is the best way of doing that, and is there anything else to look for as far as maybe damage done. And how bad could this be for my quad, i will note it starts fine and runs fine. Any help appreciated.
Josh
Old Oct 27, 2006 | 03:08 AM
Bear4570's Avatar
I would suggest you pull the air box off the carb and remove it from the quad and hose it down inside. Let it dry and reinstall.
Old Nov 2, 2006 | 09:16 PM
dumming's Avatar
I also have a 500 auto 2005 water came into the air box, which got into the crank case breather tube. It has now ruined my motor. Have you ever heard of this problem happening?
Old Nov 2, 2006 | 09:39 PM
Bear4570's Avatar
If you get water or debris in your intake system or carb or into the crankcase you need to do something about it ASAP. Carbs get cleaned and rebuilt and all the intake system gets cleaned out. Water or debris in the crankcase MUST be removed. Change oil and filter several times until no trace of water. If nothing else, drain the oil and filter and flush the crankcase with kerosene and fill with use new oil and filter. Run for a short time (an hour or 2) and change oil and filter again. Yes, water in you oil will ruin your motor. Water in the air box can ruin your cylinder walls and rings.
Old Nov 3, 2006 | 06:53 PM
swampyjunior's Avatar
HickFisher,
As was already stated...Get that water and junk cleaned out. The faster the better.
Bear is 100% correct on the damage that crud can cause. My experience this last year with getting water into my oil (presumably through the crank case vent tube) on my 400 was not good. After doing some swimming and mudding with my 400 she checked out fine. One month or so later when the temps dropped to below freezing the water foze in the oil cooler blocking oil flow. We all know what that causes!
Needless to say it took about $1300 in parts to repair the tp end on the engine. My lesson learned was to ALWAYS check the bottom of my intake baox after each ride through deep stuff. If I even suspect water got into the crank case and oil. I pay the $30 and change the oil and filter. It is far cheaper than the alternative.
I clean my air box by removing it and spraying it with Armor-All cleaner degreaser, scrubbing with a long handled brush and hosing it out. I might add that I had to change the way the box bolted in as the rubber grommeted screws that hold it in place are not the best.
You may also need to clean the little flapper valve ionthe bottom of you intake box and check that your intake lid seals the box tight.
Hope this helps.
SJ
Old Nov 3, 2006 | 08:39 PM
dumming's Avatar
this is dumming with the 500 with water in the oil ihave 400 miles on my 500and this happened like on my 3rd ride and i think that it is a poor desigh with the crankcase vent in the air box the warrenty people are saying misuse andthey do not want to pay so imtrying to find some people that this happen to and feel like i do because if that tube was not there the water would not get to the grakcaase motor would shut down from the water empty iar box andresum riding im trying to say it is a factory recall in the making my crank and bearing went out onmy 500 coast to repear is 3500 dollares they say the mortor ran about 5 minn and that all it took pulled it back to camp and train the iol changed oil 10times and on my next ride she went out on me brought to dealer and they said there is mud incrank case still so if any had this happen and feel the same mabe i can prove that it is a pore design with some help from other people
Scooter's Shop
23
Oct 22, 2015 07:04 PM
Sassinm1
Sep 30, 2015 04:23 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
MPDano
1) Engine problems..
Sep 20, 2015 09:48 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
