Clicking when I turn
Old Dec 27, 2006 | 05:38 PM
Crypto's Avatar
Default Clicking when I turn
I searched the forum and most signs of clicking, point to bad CV joints. I check the joints and they seem to have very little play (grabing the shaft and shaking while rotating the wheels). On a lift, I have slight movement out of the joints on either side. Is it normal to hear some clicking during a turn. Seems to be the left rear when I turn left on any surface.
thanks
Old Dec 27, 2006 | 07:34 PM
v2rider's Avatar
I have the same exact thing, at slow speed, and it sounds almost like a *** on my tire is hitting something, but its not. Any help would be appreciated! Mine isnt really a "click". Its like i described
Old Dec 27, 2006 | 07:48 PM
Bear4570's Avatar
thanks
The only way to check CV joints is to disassemble and inspect. If you have a CV joint with enough slop in it to feel it, it should have failed long ago. Could be a bad wheel bearing. The difference in stress on wheel bearings in turns compared to straight ahead is about 10 to 1.
Old Dec 27, 2006 | 07:58 PM
Crypto's Avatar
thanks Bear. I guess if I tear it apart to look at them I might as well replace the joints. Right? Thing is, for my model, it looks like I have to replace the entire shaft, as the joints don't seem to be availab;e seperately.
When looking at the joints, do I simply look for the worn needle bearings in the u-joint itself?
thanks again
Old Dec 27, 2006 | 08:27 PM
rango726's Avatar
i just brought my quad in for a clicking noise when i steer.it is mostly when im stopped but sometimes happens at a slow roll. and it always clicks in the same spot. they couldnt find anything. they said they checked all steering components.cv joints etc and nothing. mine started when i was crawling over some rocks my wheel cut to the right and i heard it.if you guys find anything let me know
Old Dec 27, 2006 | 10:20 PM
Bear4570's Avatar
thanks again
CV joints are not U-joints. There are no needles. There are 3 ***** in each joint and all cats have the one CV joint attached to the axle, so it isn't cheap. I would suspect the wheel bearings as the problem long before the CV's. To tear up a CVs takes a torn boot and to just keep running it untill the water destroys the joint.
Old Dec 28, 2006 | 06:50 AM
Crypto's Avatar
I'll have to try to find a picture of these so I understand what I'm working with before I start.
Thanks again. You're a wealth of information!
One more question, Is it necesary to have a tool for those bands on the cv boots? Is there a trick to tightening without a tool?
Old Dec 28, 2006 | 11:37 PM
Bear4570's Avatar
Try here for parts pictures and numbers;
Arctic Cat Parts
No you don't need a special tool. No trick, common sense. You can use long tie-straps instead of the stock clamps too.
Old Jan 8, 2007 | 10:05 PM
yearmax's Avatar
I have a 01 400 and I would like to know how much play is to much for the wheel bearing if there should be any at all?
Can anyone help me with this ?
Old Jan 24, 2007 | 03:05 PM
Williebee's Avatar
There shouldn't be any play in the wheel bearing !
