have a brake problem -- any help ?
Old Jan 8, 2007 | 06:36 PM
Bear4570's Avatar
Default have a brake problem -- any help ?
You might concider upgrading to the 2005 master cylinder as mentioned earlier. I have had no trouble with mine.
Old Jan 8, 2007 | 06:42 PM
jeepguy's Avatar
I can let you know next week as mine should be here Thurs or Friday.
Old Jan 9, 2007 | 12:05 AM
swampyjunior's Avatar
Not sure if this will help or not but I do know of someone who had a similar problem and they were using DOT 3 brake fluid. They used DOT 4 as the service manual suggested and their problem was fixed.
I do not know the difference between Dot 3 and DOT 4 brake fluid. I believe one is rated for a higher temp than the other so it could have a higher viscosity or something.
SJ
Old Jan 9, 2007 | 03:32 AM
Bear4570's Avatar
Now that Swampy mentioned it I too remember that Dot 4 is required for a reason.
Old Jan 9, 2007 | 09:57 AM
  #15
jeepguy's Avatar
I used DOT 4 and had no luck. All the parts to swap to a 2005 system was only 200 bucks, I think the master cyl for the 2004 was nearly that much by itself.
Old Jan 9, 2007 | 07:58 PM
  #16
catdude's Avatar
pretty sure that the master cylinder is gone. I unhooked the brake line from it, took it right off the bike, filled it with fluid and pumped on the shaft --- no pressure built up.
There seems to be lots of play in the shaft and I noticed small air bubbles come out from around the rubber boot.
also, I was already using DOT 4
thanks everyone for your input
[img]i/expressions/face-icon-small-smile.gif[/img]
toonces
Oct 16, 2019 12:11 PM
Sandman2.0
Jul 21, 2015 09:03 AM
Chuck188
Jul 17, 2015 02:45 PM
timster911
Jul 13, 2015 01:57 PM
sublime250
1) Engine problems..
Jul 11, 2015 11:52 AM
