tips for navigating RUTS!
Old Jul 16, 2007 | 11:09 AM
Junkman673's Avatar
Default tips for navigating RUTS!
My '01 Artic Cat is the worst ATV I've ever ridden for finding ruts and jerking the handlebar out of my hands. Especially going slowly down a hill and using the brakes. I actually rolled it this weekend!
Most other bikes I've ridden have seperate rear brakes and i'll use them around downhill ruts. Any advice?
Old Jul 16, 2007 | 01:31 PM
buckaroo50's Avatar
You may want to mess with your suspension. Read the post 'How to make the AC handle better" there could be some stuff in there that would help.
Old Jul 16, 2007 | 10:11 PM
FastestBlaster's Avatar
dont they have rear brakes like the foot lever on the right?
Old Jul 17, 2007 | 09:53 AM
Junkman673's Avatar
Mine doesn't have a foot brake at all.
Old Jul 20, 2007 | 03:07 PM
Kawa3's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: Junkman673
Mine doesn't have a foot brake at all.</end quote></div>
What AC do you have? also it should have a foot brake on the right.....did you buy it used?
Old Jul 20, 2007 | 03:14 PM
Junkman673's Avatar
i've got a 2001 AC 500 manual. Yes, I bought it used.
Old Jul 20, 2007 | 03:42 PM
Honeyduck96's Avatar
First off, check out your A-arms and suspension...
http://www.cpsc.gov/cpscpub/prerel/prhtml02/02510.html
The '01 500's had a linked braking system, but usually these systems have a foot lever that will control the rear brake only. Since you bought yours used, is it possible that it was removed/broken off at some point? If they didn't come with a foot control you're S.O.L.
Since your unit is a manual, are you going downhill in a low gear? The engine braking should keep you a a controllable speed.
Old Jul 20, 2007 | 04:57 PM
deanz400's Avatar
stay out of the ruts ,sorry couldn't resist
Old Jul 21, 2007 | 03:48 AM
swampyjunior's Avatar
Both my machines did similar things with the stock tires. After replacing the stock tires and changing to a set of Highlifter HD springs set tot he highest setting I rarely have this happen anymore.
So I would say to adjust or tune your suspension to your "main" style of riding. Also check your shocks/springs out real good as the weight of these machines causes the shocks/springs to become weak. Weak shocks and springs allows the steering to roll under easier.
While you are at it check your wheel alignment. I believe its 1/8 inch toe in.
SJ
exmotocrosser
Sep 26, 2015 08:18 AM
MikeyBoyesq
Sep 22, 2015 10:02 AM
black_thunder
Sep 20, 2015 10:21 PM
cornermike
Sep 10, 2015 08:30 AM
Technical and How-To Articles
Jul 2, 2015 01:34 AM
