Cat 700
Old Sep 19, 2007 | 11:01 PM
JT 384's Avatar
Default Cat 700
Does anyone know if the 2008 700EFI have a pull cord?
Thanks
JT
Old Sep 22, 2007 | 11:23 PM
700vtwinman's Avatar
Default Cat 700
I don't know, but the dealer is getting all his 2008's in around mid October. I am going to look at the Thundercat and the new Prowler 700H1 efi XTX.
Old Sep 25, 2007 | 03:46 PM
JT 384's Avatar
Default Cat 700
Have the 2008 bike and no pull cord, also the little darlings changed the racks on me.
For anyone who wants to know the pull cord kit is $168.00
Old Sep 27, 2007 | 12:48 PM
Catterman's Avatar
Got Milk!
Blaming Guns For Crime Is Like Blaming a Spoon for Rosie O'Donnell being Fat!
Default Cat 700
Ya I would rather have the bigger rack - Bigger racks are better to look at too [img]i/expressions/face-icon-small-happy.gif[/img] [img]i/expressions/face-icon-small-happy.gif[/img] [img]i/expressions/face-icon-small-happy.gif[/img]
I had a pull cord on my 650 H1, it was worthless, no way could I even pull that sucker.
Old Sep 27, 2007 | 09:59 PM
roamerr's Avatar
Default Cat 700
My 2006 650 H1 will occasionally (once out of 200 times) not start when I push the start button. It just does nothing but dim the lights. This is due to the piston stopping almost top dead center and the battery being too weak to turn it over under full compression. I just pull the cord a little and it moves the piston enough. I then push the starter button and turns over very easy and fires right up.
What do you do without a pull start? I realize that my 2 yr old battery may need replacing but it's nice to know the pull starter is there.
Old Sep 28, 2007 | 11:25 AM
Catterman's Avatar
Got Milk!
Default Cat 700
<div class="FTQUOTE"><begin quote>Originally posted by: roamerr
What do you do without a pull start? I realize that my 2 yr old battery may need replacing but it's nice to know the pull starter is there.</end quote></div>
I guess that is a good use of a pull starter.
I have owned Arctic Cat ATV's since 1999 and NEVER have been able to start any of them with the pull cord. - Nor have I needed to. Get yourself an Odyssey battery and you will be set for 7-9 years. [img]i/expressions/face-icon-small-happy.gif[/img]
Old Sep 28, 2007 | 11:31 AM
roamerr's Avatar
Default Cat 700
Catterman -- I actually have an odyssey on order.
I do question whether I could pull start the 650. If it was cold I highly doubt it since the choke is electric. With a dead battery I would expect the choke to not work....
Old Sep 28, 2007 | 11:39 AM
Catterman's Avatar
Got Milk!
Default Cat 700
Good point on the choke roamerr. Let us know how you like that battery!
Old Sep 28, 2007 | 09:20 PM
Default Cat 700
I have actually pull started my kawie bf750 a couple of times. I was out in the 25,000 acre deer lease and was using some additional lights I hooked up to it to help us see a deer stand we was trying to move. After about 15 minutes with the lights on (motor was off), it woundn't start much less roll over. So, I was afraid to try thinking this 750cc motor was going to yank my arm off. I pulled it until I felt the compression ease up and then yanked with one hand. To my suppirse, it fired right up and wasn't that hard. Later on, I was told there is some sort of decompression device that allowes the pull start to work much eaiser. Not sure if this is true, but I did start it.
