How big can i go?
Old Jul 7, 2008 | 05:33 PM
devinbright's Avatar
Default How big can i go?
I just purchased a artic cat 500i 4x4 manual shift. I am looking for more grip than stock obviously, and have a set of 30x12x12 itp mud light xxls on my previously running brute, motor blew. I was just wondering if anyone knew if they would fit on my cat without a lift. And even if i got a lift for it would the 500 pull them?
I am planning on getting a pipe, jet kit, and air filter. Any response welcome.
Old Jul 7, 2008 | 05:59 PM
4wheelingaaron's Avatar
Anything over 27" require a lift kit. Some wont even take 27", arctic cat will take a 27" and smaller. I dont even think they recommend anything over 27" with a 700cc or smaller.
Old Jul 8, 2008 | 07:22 AM
CATSKINNER's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: 4wheelingaaron
Anything over 27" require a lift kit. Some wont even take 27", arctic cat will take a 27" and smaller. I dont even think they recommend anything over 27" with a 700cc or smaller.</end quote></div>
What are you talking about?
The 500 man. will handle 30" tires without a lift.
Of course the manufactures are not going to recommend anything over 26". It's all about liability and warranty issues with oversized tires.
Try a search.
Old Jul 8, 2008 | 09:58 AM
Thanks CATSKINNER, i stuck them up to it yesterday and it looked possible but close. One more question. Will it hold the 12 inches of width with that tall a tire with stock rims? Thats what looked closest with me just looking. looked like it might hit the plastic fuel cell in rear. and possibly the shocks in the front?
Old Jul 8, 2008 | 02:56 PM
mitchetr's Avatar
I am running 25X10X12 Mud light on a '04 400 4X4 AC. Can I be doing any damage to the engine/tran/clutch. I try to keep it in low through the mud and hills.
Old Jul 8, 2008 | 05:40 PM
I am going to say that you have nothing to worry about with 25's even in high range on mid size hills and mud. The only reason i would run low with 25's is if pulling on someone, pulling a trailer, or in/one some seriously thick or steap hills or mud.
Old Jul 9, 2008 | 12:54 AM
CATSKINNER's Avatar
The worst case scenario, you may have to install wheel spacers. I have a friend that ran 12" wide Executioner tires all around and he had no rubbing at all. He absolutely hated the way it handled with the wider front tires so he went back to 10" tires on all four and will never look back. The wider tires will be hard on axles and ball joints and will also cause a power loss but I have never heard of any engine or transmission damage.
Old Jul 9, 2008 | 01:25 AM
nelsonsrick's Avatar
I just got rid of my 06 500 manual. I had 27" mud lites and liked it for low speeds. But I lost almost 2 gears on uphill roads. I also had a problem with either being to low or to high geared in the snow and mud. The quad would have to be a 10 speed not 5, I always felt I needed a middle gear.
I thought it was too much for a 500....accept slow speeds, low range.
good luck... I did like the machine, great for down steep hills
Old Jul 9, 2008 | 09:29 AM
mitchetr's Avatar
thanks guys for the postings.
Old Jul 9, 2008 | 02:29 PM
04500icat's Avatar
ive got 27x12 on the back and 27x9 on the front.and its fine.i did lose some on the top end but who needs to go 60mph in the mud or trail anyway???
