700 H1 noise
Old Jul 17, 2008 | 01:04 PM
JMR866's Avatar
Default 700 H1 noise
Is it normal for the 700 to make a noise while slowing down? Sounds like something grinding as you slow to a stop and you can feel a vibration.
Old Jul 17, 2008 | 05:30 PM
tancat500's Avatar
I would have to say no its not suppose to make a grinding noise!! As to any advice of what it might be, where is the noise coming from?
Old Jul 18, 2008 | 04:47 PM
JMR866's Avatar
Engine/transmission area
Old Jul 18, 2008 | 06:10 PM
tancat500's Avatar
Assuming its an auto, sounds like maybe a bearing in the clutch housing. You might try taking the housing off and see if you can pin point the problem. There was another guy that was having a similar issue and it turned out to be the bearing on the outside housing. he lubed it up and hasn't had anymore trouble.
Old Jul 25, 2008 | 06:14 PM
unclened's Avatar
Default 700 H1 noise"></title><script src=
mine had the same noise, the bearing (in the clutch cover) spun on the shaft - bearing glazed on the inside, don't know if there is a size problem yet
mrtidy
Feb 3, 2016 05:00 PM
Ahtatu
Sep 28, 2015 12:14 PM
kbazzy
Sep 26, 2015 11:26 AM
firsttimerider
Sep 20, 2015 09:07 PM
