cat wont do nothing
Old Aug 24, 2008 | 01:40 AM
500ac 's Avatar
Default cat wont do nothing
i have a 2002 500 artic cat and i was ridding down a trail and shut down have no spark no ignition power to starter all fuses are good
Old Aug 25, 2008 | 12:33 AM
swampyjunior's Avatar
500ac
You might try looking at where the wiring harness goes down the steering column. There are a couple of wiring harness plugs there that will kill the machine if the come unplugged. It is a tight fit for those wires and they bind.
SJ
Old Aug 25, 2008 | 09:35 AM
Limecat650's Avatar
Also, look for any shorts while your there. My 650 did the same thing. There was a little burr from the welding on the steering shaft that wore through some of the wires and caused it to die. Took the plastics loose and found it. A little filing and elec tape...good to go!
Old Sep 23, 2008 | 09:33 PM
skoalman63080's Avatar
try the silonid i had the same problem its like you turned the key off and no batt
Old Sep 23, 2008 | 09:49 PM
Mudbug5's Avatar
Skoalman, you talking about the starter silonoid?
500AC, do you have lights, brake light, inst. cluster come on?
Old Sep 24, 2008 | 07:06 PM
yes stater silnoid i had notheing it was like you unhooked the batt
Old Oct 6, 2008 | 05:09 PM
arcticcattrv's Avatar
my actic cat trv do the same think it was the pick up coil,in the stator .find one in rmstator.com
