dash lights
Old Aug 27, 2008 | 01:49 AM
jsnoking's Avatar
Default dash lights
I have an artic cat 400 and the dash lights dont work, the high beam will light up but the other lights nothing,any thing will help thanks
Old Aug 27, 2008 | 04:13 PM
Limecat650's Avatar
Default dash lights
high beam as in the headlight, or high beam indicator? checked fuses? wires under pod, any freyed? cut?
Old Aug 27, 2008 | 04:34 PM
jsnoking's Avatar
Default dash lights
the high beam lights and indicator both work,checked fuses under right rear wheel well, what wires under pod, all connections look good and none cut or freyed.
Old Aug 27, 2008 | 04:51 PM
Limecat650's Avatar
Default dash lights
does it crank/run? just no pod?
Old Aug 27, 2008 | 06:47 PM
jsnoking's Avatar
Default dash lights
The battery was dead but i charged it and it will crank, and pull start just fine! does anybody know if they are LED or bulbs in the pod?
Old Sep 1, 2008 | 03:14 PM
Bobmack's Avatar
Default dash lights
it is a pod all the bulb are together replace all at one time
http://cgi.ebay.com/ebaymotors...rdZ1QQsspagenameZWDVW
http://cgi.ebay.com/ebaymotors...QrdZ1QQsspagenameZWDVW
Old Sep 1, 2008 | 07:49 PM
mountainclimber's Avatar
Default dash lights
I have my tempature light that flickers sometimes when i am riding, and when im in neautral the reverse light will flicker while the nuetral light is on also could this be a pod problem?
Old Sep 3, 2008 | 12:43 AM
dfreelang's Avatar
Default dash lights
I have an 2003 I have replaced the pod 3 times. ones under worrinty and now 1,3,R light don't work i have come to th conclution that I am not going to pay $65 again. They lasted about 1 year then went out again.
Old Sep 3, 2008 | 09:39 AM
Limecat650's Avatar
Default dash lights
did you put dielectric grease around your connections everytime?? I haven't heard of that before...If you replace your display, put de grease around it before you install it. it will keep the water and the elements out...
Old Sep 3, 2008 | 06:01 PM
Default dash lights
dfreelang... did any of your lights randomly flicker?
