ARCTIC CAT
Old Nov 9, 2008 | 09:05 PM
MIKEY1981's Avatar
Default ARCTIC CAT
HELLO GUYS IF SOMEONE COULD BE A LITTLE MORE SPECIFIC ABOUT THE ENGAGEMENT ROD TRICK HOW TO AND WHICH DIRECTION TO BEND IT THIS SOUNDS LIKE A WINNER PLEASE HELP ME GET THIS CAT GOING. WHEN I GET THE CHANCE I'M GOING TO DO THE AIR BOX THING WITH THE HOSE THANX GUYS
MIKE
Old Nov 9, 2008 | 09:36 PM
CatKrazy's Avatar
Default ARCTIC CAT
I dont remember exactly. you will have to look at the rod and see which whay it need to be modded. some even welded a extra length to the rod where it neets the lever on the diff. push in on your lever, and then go and look by the diff, and see which way it needs to go. Also disconnect the rod from the lever on the diff, and use your hand to engage the diff lever farther. it will give you an idea of what you need to do.
Customer Service #1
May 15, 2020 08:46 AM
shimanok2
Jan 29, 2016 07:37 PM
brad patnoe
Sep 23, 2015 06:44 PM
vtech
Help With Forum Software!
Sep 2, 2015 05:59 PM
Sep 1, 2015 01:45 AM
