arctic cat 250 2/4
Old Aug 23, 2009 | 12:34 PM
lcb0027's Avatar
Default arctic cat 250 2/4
im trying to replace the rear drive seal that the axcel goes through. ive taken everything off brake rotor and calipers. is was just wandering if there was a clip that i need too remove for it to slide out on the right side.
Old Aug 23, 2009 | 11:21 PM
TexasRoadlawyer's Avatar
No Ruts, No Glory
Do yourself a HUGE favor and buy a factory service manual (not an aftermarket one) They are a little more $$$, but they will save you money by giving you the info for you to do the job correctly
Old Aug 27, 2009 | 06:41 AM
mrj's Avatar
mrj
I had a 05 300 AC it is basiclly the same as the 250. To remove the axle after removing the caliper, hub, axle nut and upper a-arm bolt if she is a FIS just give it a pluck. The axle has a internal round clip much the same as a automotive cv joint. The spring steel circle clip will collapse as it passes thru the indentation in the axle housing. Dont forget to put a drain pan under the seal you are removing because you will loose some motor oil.
Happy ATVing
MrJ
Customer Service #1
May 15, 2020 08:46 AM
shimanok2
Jan 29, 2016 07:37 PM
brad patnoe
Sep 23, 2015 06:44 PM
vtech
Help With Forum Software!
Sep 2, 2015 05:59 PM
Sep 1, 2015 01:45 AM
