Drive Belt (i think )
Hey all, I just got done (almost) rebuilding a friends 400 4X4 automatic. All seems good so far except when I go to put it in gear, (H or R ) it grinds a little
( I am pretty sure thats normal ) and dies. If I give it some gas, put it in gear quick I can go, but when I come to a stop it dies. Is this due to the V-belt not adjusted properly ? I followed the service manual, I dont understand he 3/8 shim thing though, I did it still cant get it. Or is this something else ? Thanks in advance. |
one way bearing
Originally Posted by ktosca
(Post 2917407)
one way bearing
(Post 2917407)
Ok thanks, but the rebuild did not go that deep, I did not have to remove the clutch nor the bearing ? And according to the owner it did not do this before.
Drive Belt
On the 400 the the primary c lutch sheaves are tight against the belt .There is no clearance.The centrifugal clutch actuates when the engine accelerates.Sounds like a problem with the cen.clutch or one way bearing gone south.
Thanks guys.
You were right, it was the one way bearing. I should have checked it before I put it back together. All set now. Thanks again for the help. |
