2004 Arctic Cat 500 4X4
Old May 27, 2010 | 11:26 AM
RobCourtis's Avatar
Default 2004 Arctic Cat 500 4X4
Hey all,
Im new here. i ride a 2004 AC 500 4x4. I love my kitty, but have encountered a problem that i need advice on.
my atv stalls out and dies sometimes when driving. I got the battery tested and it was fine. from fully charged the quad will start and drice fine for a couple rides then it will start to bog out when i give it throttle. from there it will shut down and i will be unable to start it. the digital display will not turn on. if i boost it with another battery it will start and idle but as soon as i use an accsory it dies.
help please. i believe it is the charging system but to replace a magneto is not cheap so i am hopeing one of you can help me figure it out inorder to avoid that purchase.
Thanks Everyone.
i dont check back very often so if you have some advice could you email me
robertcourtis@gmail.com
Thanks again
Robert Courtis
Old May 28, 2010 | 11:25 PM
weez440's Avatar
when i had a bad battery i would winch with it and as soon as i started drawing power the engine would just die like you said. i know you said you checked the battery out but did you make sure all connections are clean on the battery and you have good grounds?
Customer Service #1
May 15, 2020 08:46 AM
2many2ride
Sep 27, 2015 04:35 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Bernhard
Sep 25, 2015 12:45 PM
Sw00p
Sep 24, 2015 02:50 PM
