98 454 4x4 not firing
Old Mar 10, 2011 | 04:12 PM
georgiagator57's Avatar
Default 98 454 4x4 not firing
I just pulled my old four-wheeler out and changed the oil clean the carb and gas tank. It will turn over but not fire from the plug wire any advice?
Old Mar 10, 2011 | 05:29 PM
Dirtyone55's Avatar
Ignition coil?
Old Mar 10, 2011 | 05:40 PM
snow racer's Avatar
Make sure it is in the RUN possition.
Old Mar 10, 2011 | 05:45 PM
Kerbbirds's Avatar
Stator? is there none from the wire or from the plug?
Old Mar 10, 2011 | 08:26 PM
The starter turns and there is no fire from the wire. Where is the coil at??
Old Mar 11, 2011 | 03:16 AM
Williebee's Avatar
Post 98 454 4x4 not firing
Just follow the spark plug wire it's connected to the ignition coil , another thing what kerbbirds was asking if when you remove the spark plug and put the plug wire boot back onto the plug and touch/ground the spark plug to the cylinder jug and turn the engine over do you get spark then !
If it doesn't fire doing this it could be the coil or just a broke/burned spark plug wire causing the no firing problem , i had this problem on a friends 93 Polaris Sportsman 500 HO , i removed the coil and took it to my local AC Dealership the owner checked the coil and it tested good but when she took the probes and tested the plug wire boot to the coil she found a break in the plug wire its self to be the problem ; she then removed to old plug wire from the coil and put a new one and the problem was solved !
I hope you have the same luck because the new spark plug wire was only $3.00 + tax , these wires can go bad the same as the plug wires on a car , good luck and i hope it's as easy of a fix as my friends was !
williebee..........
ultangler
Nov 30, 2024 01:35 AM
mrtidy
Feb 3, 2016 05:00 PM
IMLN
Sep 28, 2015 03:32 PM
Elkaholic
Sep 6, 2015 02:44 PM
Jason An Stacy Jones
Utility ATVs
Sep 6, 2015 02:25 AM
